Latest post 11-19-2008 9:58 AM by stotty1111. 9 replies.
Page 1 of 1 (10 items)
  • 11-12-2008 5:15 AM
    • deaddruid
    • Top 500 Contributor
    • Joined on 05-24-2007
    • Malvern, Worcestershire
    • Posts 247
    Link room connectivity
    I intended to have a main room Avant, and a link room MX3500, connected by a converter. However, the Configuration Guide states that I won't be able to control the STB on the Avant from the MX3500. Is this correct? It rather defeats the purpose of linking the devices.
    Mark
  • 11-12-2008 5:35 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Link room connectivity
    hi
    a little off your question but you may be able to point me in an appropriate direction!
    you refer to a connectivity guide where would i find one of these - iam a virgin in this territory i have a bc9300 to connect to an mx4002 initially
     cheers
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 11-12-2008 6:08 AM In reply to
    Here, if you are a paying member: http://www.beoworld.org/manuals_view.asp?pid=1238
    It is a software that runs on you PC. You enter the config and it tells you how to configure it.
    Connecting a BC9300 and a MX4002 is done by using a Beolink Video converter. You will not be able to transfer the sound of the TV to the Hifi. You'll be able to do the other way round. p.
  • 11-12-2008 6:56 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    thanks for that - i could use thespeaker outlets on tv to aux in on bc to get that sound but it is messy!
    salut
    t
  • 11-12-2008 6:57 AM In reply to
    Are they both in the same room?
  • 11-12-2008 8:00 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    yes they are , within 2 m of each other!
    t
  • 11-12-2008 8:05 AM In reply to
    stotty1111:
    t
    Ok... the workaround I suggest: Connect all speakers to the TV.
    Beosound in option 0, TV in option 6.
    You can operate everything fine with the remote. But you cannot start the music using the local controls on the Beosound.
  • 11-19-2008 6:35 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    apologies for not responding earlier!
    how would the 4002 and the 9300 be connected, ie type of cable etc by power link or thro the mcl socket on the tv?
    may be a stupid question but i am some way from a local dealer to talk thro' my perceived problem - otherwise point me atthe info or where to find it on the site please
    ta in advance
    tony
  • 11-19-2008 7:00 AM In reply to
    A BeoLink Converter is required to be able to connect the video and audiomaster, part No. 1161166/1161466
    Connect the AUX/TV socket of the audiomaster to the BeoLink Converter's AUDIO AUX LINK socket using a 7/7-pin DIN cable.
    Connect the BeoLink Converter's Master Link socket to the Master Link socket of the TV-set using a MasterLink cable.
  • 11-19-2008 9:58 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Thanks for that
    salut
    t
