Latest post 11-12-2008 6:11 AM by PhilLondon. 26 replies.
Page 1 of 2 (27 items) 1 2 Next >
  • 11-10-2008 9:02 PM
    Beocenter 2300 question
    I'm curious...does the beocenter 2300 have the exact same display as the beosound 3200? does the display light up information in  green like the 3200?
    thanks
  • 11-10-2008 9:35 PM In reply to
    Re: Beocenter 2300 question
    Yes Smile
  • 11-10-2008 9:59 PM In reply to
    so the display from 1991 is the same as the 3200 of today? i thought the display had a red light on the 2300 i guess i was wrong.
  • 11-11-2008 12:59 AM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    They both have a red light when in standby mode only.  Below is 2300, then 3200.  Pretty much the same, as Llewelyn mentioned.  The information that shows up is different however - e.g. the 3200 has RDS; the 2300 doesn't.
    (I knew there had to be a reason why I own so much B&O Laughing
  • 11-11-2008 1:07 AM In reply to
    And of course masterlink which 2300 not have...
    Do anybody knows can you upgrade 2300 with masterlink ?
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
  • 11-11-2008 1:16 AM In reply to
    Actually, my Beosystem 2300 has RDS. It wasn't standard, but you could fit a module (# 2201).
  • 11-11-2008 2:05 AM In reply to
    nmartin771:
    The Beocentre 2300 itself cannot be upgraded for Masterlink, but you CAN use a Masterlink converter which is a seperate box to connect to the Masterlink.
    Regards Keith....
  • 11-11-2008 6:58 AM In reply to
    Hi Keith,
    And Masterlink converter I need to plug in to aux or powerlink ?
    Cos allso I want to attach ipod to 2300 but only way as I know is aux - minijak
    Actually what I want is :
    BC2300 with BL4000 linked to BC1  and ipod linked to this setup.
    Maybe someone have solution for me ?
    thanks
  • 11-11-2008 7:04 AM In reply to
    The converter goes to the AUX.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
    The Beolink converter needs both the Aux and the Powerlink. You then connect all speakers on the TV.
    You can connect you iPod to the TV, if you have a free Scart or Camcorder entry.
    If you do not want to connect all the speakers to the TV you do not need the Powerlink cable between the BC2300 and the Beolink converter.
  • 11-11-2008 8:11 AM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    I'm adding my own Beocenter 2300 question to this thread :
    I've got a Beocenter 2300 from 1997 or something... And a friend of mine can sell me his Beosound 3000 at a really good price. Considering the resell value of my 2300, it would cost almost nothing for me.
    So the question is : do I lose something if I go from 2300 to 3000? I know that I will gain the integrated Beolink (but I already have a Beolink converter with my 2300), and lost the 2way remote (not bad : I'm using a Beo4).
    But do I lose a bit of robustness, or quality of the CD player for instance, or is the Beosound 3000 better in every aspect (no cost reduction on components)?
  • 11-11-2008 8:18 AM In reply to
    The 3000 will integrate much better with any recent TV. Any will function fully with the Beo4.
    You can programme the timer using the local controls. No need for a 2 way remote.
    You will also get an extra Audio AUX In, as it is not taken by the converter. You can connect an iPod or an Airport Express for example.
    If you're gonna get a Beosound 3000, make sure it is N.MUSIC compatible... There are several software versions.
  • 11-11-2008 8:21 AM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    Thank you Phil. If I want it to be N. Music compatible, I only need a software update, isn't it? (I'm not fond of N.Music, I prefer the Airport Express solution...)
    No downgrade of CD transport, or less robust mechanisms?
  • 11-11-2008 8:28 AM In reply to
    Even if you are not fond of N.MUSIC, I would still get a compatible one... just in case. The upgrade might be costly as well. I think you need to change a chip.
    As I said, on the Beosound 3000 you will be able to use the A-AUX In socket as it is not taken bu the converter.
    I cannot comment on the quality. I do not know.
  • 11-11-2008 8:35 AM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    And how can I know if it is N.Music compatible without Beoport?
  • 11-11-2008 9:28 AM In reply to
    • Foxtrott
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Vienna, Austria
    • Posts 500
    mbee:
    Hi mbee!
    For N.MUSIC you will always need Beoport as Beoport is the dedicated interface between the Beosound and the computer.
    The point that has already been raised is that not all BS3000 are automatically N.MUSIC compatible. The early version of the BS3000 built in 2000 (with shiny front and small clamper just as the BC2300) may need an SW upgrade. My BS3000 is an early one and I had the SW upgraded to the N.MUSIC compatible version 2.12 (although I do not use N.MUSIC).
    The BS3000 units with the large clamper and the grey front are N.MUSIC compatible "ex-works".
    Hope this helps
     Foxtrott
    "The first thing we do, let's kill all the lawyers."
    Henry VI, Part 2 William Shakespeare
  • 11-11-2008 10:04 AM In reply to
    There are 3 ways to get N.MUSIC: Beoport (Beolink PC2), Beomedia 1 and now Beomedia 5.
    If a system is compatible with N.MUSIC it will be compatible with ant of this N.MUSIC server.
  • 11-11-2008 10:40 AM In reply to
    • Christian
    • Top 100 Contributor
    • Copenhagen, Denmark
    • Posts 626
    You do not have to have a N.MUSIC compatible music system when using BeoSound 5...
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 11-11-2008 10:44 AM In reply to
    Christian:
    Can you have a Beocenter 2500, let's say, a Beovision 7 and a Beosound 5 in the same masterlink system, all happy together?
    I know you can have the Beosound 5 on its own. It has been said it can be integrated with an existing Beosound, but in that case I think it needs to be N.MUSIC compatible. Although I hope I am wrong as mine isn't!
  • 11-11-2008 10:51 AM In reply to
    • Christian
    • Posts 626
    PhilLondon:
    Christian:
    I am not completely sure, but I think so.
    BTW haven't noticed your name change before now. Initially I thought: "Who is the PhilLondon guy, and how did he manage make so many posts, without me seeing them before now..." Hmm Laughing
  • 11-11-2008 3:49 PM In reply to
    PhilLondon:
    Let see if I understand:
    I want to hear music from my tv to the speakers and to play music from iPod when tv is OFF ?
  • 11-11-2008 5:40 PM In reply to
    When you connect an audio source on a video entry, like the iPod on the scart, you can listen to it without turning the TV on by pressing AV before the source.
    Let's say your iPod is connected to a scart that you have configured as V.AUX, then you can press V.AUX to listen to it on the external speakers and leave the TV tube off.
    Has your got BC1 a Masterlink socket?, Has it got powerlink sockets as well? Has it got a Surround module?
  • 11-12-2008 1:47 AM In reply to
    PhilLondon:
    YES it has all that extras Smile
    What kind of convector do I need to connect   aux-masterlink between  bc2300 and bc1?
  • 11-12-2008 2:59 AM In reply to
    Then connect all the speakers to the BC1, otherwise you won't get surround sound.
    You need a Beolink Converter 1611. Buy a second hand one from eBay, lifestyle, or another shop.
    On one side it has ML on the other side you need Datalink cable (fully cabled) and a fully cabled Powerlink cable as well. Plus the electricity.
    Beosound in Option 0, Beocenter 1 in Option 2.
    You probably need to change some settings if you want to de-activate the radio of the BC1.
    You will lose 2 way control of the BS2300 in this setup, but it remains the best setup.
    Delete any timer programming on the BS2300 you've done before doing this setup. You can use the timer inside the TV.
    As indicated before, you can use the iPod as an audio source by pressing AV-V.AUX for example.
    You can change the number of speaker used by pressing SPEAKER 1,2,3,4 or 5 on the Beo4.
  • 11-12-2008 3:00 AM In reply to
    https://www.beoworld.org/prod_details.asp?pid=983
