Die_Bogener: Hi,
the teletext problem is caused by a newer board for teletext. FastText... the AV9000 is a beautiful extended MX model :)
The same problem appears, when a MX6000/7000 is downgraded from 3.0 to 1.1... wrong teletext board. The system time will be wrong or not working.
I dont know, wether this board is compatible or maybe identical to the MX series.
Hi Martin,
Did all AV9000-versions have the 2-way-hardware inside
and only the first version had 2-way-software ?
With MX 7000 IT, i would really liked to have 2-way,
but it seems this version of MX 7000 didn't have the hardware / IR-emitter
and uses a (completely ?) different board (?), so even adding the IR-emitter & correct software
wouldn't result in 2-way-communication.
This 1/2-way comm. & different versions of products during their product-cycle/life
still is a bit confusing to me.
I was told that all BM4500 (and BM3500) used exactly the same hardware,
difference would be mainly that the software in BM3500 (and later BM4500) used 1-way software,
where the 2-way hardware was simply de-activated.
However, when i re-built a BM3500 into a BM4500 in black with mirror-panels,
i also had to use the 2-way/ IR-hardware of a BM4500,
as the BM3500 that i used as base, didn't have the hardware....
This would mean that from both BM3500 and BM4500 there are versions;
different in both hardware as software.
Apologies for my list of questions,
but i'm just curious
