Latest post 11-28-2008 6:07 AM by Steve at Sounds Heavenly. 3 replies.
Page 1 of 1 (4 items)
  • 11-06-2008 6:35 PM
    BeoCenter 9300 questions w/Beolab 8000 speakers
    I was just recently given a 9300 and Beolab 8000 speakers and have not had much luck understanding how to properly
    hook the speakers into the unit. I know it was working when it was disconnected  but do not know if all the wiring
    made it in the move from one house to another . My question is do the Beolab 8000's need a power cord attached to them
    when you open the panel on the bottoms the DIN plugs in and there is a power(or what looks to be a power connection) there under
    the pop up. Is this a standard power cable or is it a cable that plugs into a transformer don't want to plug anything in until I know.
    Oh BTW I did not get a manual which is why I am a bit in the dark. Any help appreciated.
  • 11-06-2008 6:40 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: BeoCenter 9300 questions w/Beolab 8000 speakers
    Hi there and welcome to BeoworldSmile
    Yes, the 8000s need power to them as they contain an amplifier.
    It is a fairly standard lead similar to a kettle power cord.
    You can buy a cable cover that contains both the power lead and the link cables so it looks like one big lead.
    Andy T.
    Poor me, never win owt!
  • 11-07-2008 12:23 PM In reply to
    Very much thanks it looked like a standard plugin but I will find and order the other cable set
    Thanks again
  • 11-28-2008 6:07 AM In reply to
    You need a 2pin power cable for each speaker, which has a plug shaped like a number 8.  The signal to the speakers is sent by a Powerlink cable that has 8 pin DIN plugs fitted at each end.  Again, you need one cable per speaker.  You can use any type of Powerlink cable (mark 1, 2 or 3) for Beolab 8000.
    These are freely available from eBay, your local B&O dealer, or other cable companies.
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
