Latest post 11-12-2008 5:27 AM by crissbiscit. 2 replies.
Page 1 of 1 (3 items)
  • 11-06-2008 8:36 AM
    Speed selection on Beogram 1102
    I hope somebody can advise me on this. On this deck as far as I can tell if I press one side of the button it will play a twelve inch record at 33rpm, if I press the other it will play a seven inch at 45rpm. How do I get it to play a twelve inch at 45rpm without physically moving the arm back to the start of the twelve inch record? Or does it not have this facility because of the year of manufacture? Any help much appreciated.
    What's your favourite tune?
  • 11-11-2008 4:27 PM In reply to
    • geearr
    • Top 200 Contributor
    • Joined on 03-27-2008
    • Gold Coast, Australia
    • Posts 301
    • Gold Member
    Re: Speed selection on Beogram 1102
    Hi chrisbiscit
    I think that you will have to revert to the manual mode that you outlined.  According to the original instruction manual, the following options are available:
    30cm records - Press 33
    17cm records - Press 45
    25cm records - Move pickup to first groove and press 33
    Special 17 cm records, 33rpm - Move pickup to first groove and press 33
    Hope that helps
    Geoff
  • 11-12-2008 5:27 AM In reply to
    Thanks Geoff, that does help.
    The switch cover got lost in transit so I couldn't be sure I wasn't being particularly stupid, but now I know i'm not I can relax, thanks for that!
