Latest post 05-23-2007 2:44 PM by Stan. 9 replies.
Page 1 of 1 (10 items)
  • 05-16-2007 4:13 PM
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    OT: Help me with my Mac problem, please!
    I'm at wits end.  My mac-mini started screwing up in an odd way (dock wasn't showing, couldn't do a restart) that appeared permission related so I tried to repair permissions.  The error I receive is something like Disk Utitlity has "Lost Connection" with Disk Management tool" Please quit Disk Utility.  When I look in at the log file, all I see is a "buffer overflow!" message.  Nothing else.
    Research found a very similar problem associated with iTunes 6 on Mac OSX 10.3, but I'm running iTunes 7.1.1 on OSX 10.4 (and I tried the fix anyway and it did not work).
    Deeper research found similar problems associated with a screwed up file or application, but the offending application/file would be displayed in the log file.  The "buffer overflow" I'm getting seems to happen right away.
    The disk verifies fine.
    Ok, I give up, I'll just restore the system from my backup... except the backup from 4 or 5 months ago has the SAME problem!!!
    I don't want to rebuild the system from scratch because I had a lot of problem doing this the last time... although, I suppose, given the trouble I had doing the rebuild it's quite possible that this problem has always been there.  I did a complete rebuild about 6 mos ago when my upgrade to 10.4 failed midway (I was upgrading to run eyeTV).  I don't run "repair permissions" habitually so it's possible I never caught this.
    Any suggestions aside from starting over.[:'(]
    Thanks in advance,
    Stan
  • 05-16-2007 4:40 PM In reply to
    Re: OT: Help me with my Mac problem, please!
    I would post on the Apple forum - more knowledge! Just off to repair permissions....
  • 05-17-2007 1:35 PM In reply to
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    Tried AppleCare? or Apple Genius bar?
  • 05-17-2007 2:11 PM In reply to
    Have you done anything with in your library file? Doing things like deleting the content of your reciepts folder or moving things around can cause this kind of problem.
    A quick thing to try without having to do a full install is an archive and install. This is done by booting of the CD that came with your Mac (hold down C during boot) and choosing it from the customize option half way through. Also I would run AHT just to make sure you don't have an hardware issue.
    Nicholas
  • 05-17-2007 2:57 PM In reply to
    • henrik
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Stockholm, Sweden
    • Posts 299
    Create a new user account and see if you get the same problems when logged in as the new user.
  • 05-18-2007 2:06 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    britops:
    My experience with the "Genius" bar is that the so called geniuses tend to be mostly geniuses in their own mind.
    I may give AppleCare a whirl, but haven't ever had much luck with other company's tech support.
    I will try other's suggestions... thanks for the help.
    Stan
  • 05-19-2007 11:32 AM In reply to
    • Greg
    • Top 500 Contributor
    • London, UK
    • Posts 109
    Stan:
    britops:
    Stan
    Firstly, Repair Permissions actually does nothing of any use unless you have a highly-specific permissions related issue - which are very uncommon and in any case better resolved in command line. As regards your issue, I'd reconsider your plan to keep copying back your previous setup, which is probably re-introducing the issue each time. I know it's a pain, but you'd be better off in the long run to back up what you need, wipe the thing, install and update the OS, copy your data back over and reinstall any apps etc. one at a time.
    Secondly, your comment about Apple's Genius Bar is uncalled for, IMHO, and may not go down too well with certain members of Beoworld ;-)
    Best of luck getting it sorted.
  • 05-19-2007 12:04 PM In reply to
    I have used Apple Care about 4 times and on three occasions, they were fantastic. Once I got someone who was simply not interested but I rang again the next day and they were fine.
    The Genius Bar seems to be an American feature so I could not comment.
  • 05-19-2007 1:11 PM In reply to
    • UK
    • Posts 970
    I used the Genius bar in Sheffield Meadowhall Shopping Centre and they were excellent.
  • 05-23-2007 2:44 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    Thanks.... I had no intention of restoring an image with the same problem.  I'm leaning toward not doing anything (aside from keeping my important data backed up).  As you say, repair permissions is not exactly mission critical.  The computer seems to be working after a re-boot.  Rebuilding from scratch is painful, and so why do it just because repair permissions fails?
    Sorry if I offended anybody with my Genius Bar crack.  I suppose I painted with an overly broad brush...
    Stan
