Latest post 12-02-2008 2:33 PM by Keith Saunders. 6 replies.
Page 1 of 1 (7 items)
  • 11-04-2008 4:22 AM
    • Luigi
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Figueres (Spain)
    • Posts 3,013
    Link-Camcorder?
    Hello,
    I have installed a new firmware and software for Beo5. All It´s Ok, but before the installation I used Link-Camcorder (1:000:TV:Camcorder) to see and listen in the bedroom (BV1) the ipod connected to BV3 in the livingroom (Camcorder connection), and it worked perfect. And now doesn't work. Do you know anything?
    Luis
  • 11-05-2008 11:02 AM In reply to
    Re: Link-Camcorder?
    Luis,
    I have checked out your problem using a Beovision 1 in a link room and an AVANT as the master with a camcorder connected to the AVANT.
    I set up initially a basic configuration on my Beo5 with just the two rooms and added a button for link TV as you stated it and it worked perfectly for me. Both audio and video from the camcorder being feed into the camera socket on the AVANT appeared on the link Beovision 1
    I did the same with a more complex Beo5 configuration and it still worked.
    So, I can confirm that 1:000:TV:Camcorder using the latest formware 1.34a works correctly, so I can only assume that there is something unique with your Beo5 Configuration.
    You may wish to try removing the camcorder button from the configuration, saving the configuration, then putting the camcorder button back.
    Regards Keith....
  • 11-07-2008 4:11 AM In reply to
    • Luigi
    • Figueres (Spain)
    • Posts 3,013
    Re: Link-Camcorder?
    Hello Keith,
    I don't know what happen.. but I have created a new button (1:000:TV: Camcorder) and It doesn't work. The BV1 show the camcorder of BV1, not Link. Confused
    Luis
  • 11-08-2008 9:14 AM In reply to
    Re: Link-Camcorder?
    E-mail me your Beo5 XML configuration and I will load it into my Beo5 and test it...
    Regards Keith....
  • 11-09-2008 2:06 PM In reply to
    • Luigi
    • Figueres (Spain)
    • Posts 3,013
    Re: Link-Camcorder?
    Ok, Keith! Can you give me your e-mail?
    Luis
  • 12-02-2008 1:48 PM In reply to
    • Luigi
    • Figueres (Spain)
    • Posts 3,013
    Re: Link-Camcorder?
    Keith, I have tried:
    1:000:TV:Camcorder
    Delay:450ms
    Delay:450ms
    1:000:Radio:Camcorder
    ...and it works fine! I don't understand but it works. Problem solved!
    Now I can control my ipod connected to BV3 (camcorder) through an IR repetear placed in the bedroom with my BV1.
    Thank you.
    Luis
  • 12-02-2008 2:33 PM In reply to
    Re: Link-Camcorder?
    Luis,
    I am very pleased that it is working, I am just not sure why it is working given my previous comments via PM
    Regards Keith....
