Latest post 11-04-2008 3:33 AM by timhanna. 6 replies.
Page 1 of 1 (7 items)
  • 11-02-2008 3:35 PM
    Is there Satellite Decoder for Avant 32 DVD
    Hi does any one know if there is such an addon for the latest avant 32 dvd?
  • 11-02-2008 4:12 PM In reply to
    Re: Is there Satellite Decoder for Avant 32 DVD
    Yes - there is the DVB-S module. No use for Sky but should work for FreeSat I suppose.
  • 11-02-2008 4:23 PM In reply to
    Hi and thanks, any idea of the prices? Would they be readily available from b&o?
    thanks
  • 11-02-2008 4:38 PM In reply to
    Available and stupidly expensive - £400+ when I last looked though should be less by now. Much better to to use a STB!
  • 11-03-2008 10:13 AM In reply to
    Thanks Peter, besides the cost; is it safe to assume that it will work fine for all the basic functionality, could this operate with motorised sats as well?
    Tim
  • 11-03-2008 12:08 PM In reply to
    I can confirm that DVB-S supports motorised dishes and uses the standard 14-18 control voltage as well as the 22 Khz tone control which conforms to DiSEqC 1.0 spec.
    It also supports two Conditional Access Common Interface  slots PCMCIA
    It also supports the storing of 5000 TV and 5000 Radio channels
    Regards Keith....
  • 11-04-2008 3:33 AM In reply to
    I see, Ill ask the dealer for the prices to see if its worth entertaining this solution. I pressume all I need to do is connect the satilite dish cable to the Tv and presto its done, then tune?
