tonedeaf:Relatively simple question. We really like the Beosound 1, heard it in the dealers sometime ago and was impressed by the rich sound that comes from a relatively small machine. But does it play MPEG 3?
Simple No.
But there is a work around.
Buy a cable that fits i.e. an iPod and the Beosound 1 (Lee can help you out if you want)
Then select A.Aux on the Beo4 or (from memory) press CD << and CD>> simultaniously for the same result.
Now start your portable music system and you have your compressed music through your BS1.
