After getting a Serene a few months ago, I had the SW updated to the newest level in my 4-years old Beocom 2. That implied a change of the base station as well. The Beocom 2 works OK when registered as the only set on the base station. During registering the Serene, the Beocom looses date & time, gets no signal from the base any longer and constantly demands 'load battery' before switching off automatically. I had the Beocom 2 with the dealer for some weeks, they do not find any failure. Anybody having a similar problem? Beocom 2 & Serene should work together on the same base without problems, right?
rpaul
Reinhard
Which base are you using?
1 Large, black rectangular Beoline2 Small,new version rectangular Beoline3 Pyramid Beocom 6000 base4 Older, original Beocom 2 globular base
Andy T.
Poor me, never win owt!
I am using the small, new rectangulat version. I had mz old Beocom 2 upgraded to the latest version.
Reinhard Paul
Sorry, I have no experience with the new small model.I'm sure it should work with the Serene.Any body else?
