I would like to install four Masterlink wall sockets. Ideally, each of these would have an F connector on the same unit, since I use these for aerial connection. I such a device available? If so, where would I get them from? I'm in the UK, but happy to order from overseas.
An alternative might be to buy one of those Masterlink wall sockets which also holds a normal aerial socket, and replace the aerial socket with a male-male F connector. Where could I get four of these?
Any suggestions welcome.
Mark
p.s., for the curious - I use high-grade satellite cable for aerial wiring, and use F connectors where possible. This has given me much better results than normal 75ohm coax + aerial sockets.
