Hi:
Perhaps one or all of the memory batteries have expired. They are cell type (silver discs) and are either mounted to the boards in a plastic socket or soldered directly onto them. If this is the issue (I am taking an estimated guess) they will need to be replaced. I think they are fairly standard and can be bought from a shop like Maplin. However, unless competent with electronic repair you would be ill advised to do this yourself due to the high voltages that are encountered in CRT televisions (you could in the worst case give yourself a fatal electric shock).
Hope this helps.
Graham
....well meant but of no use i'm afraid: no such batteries in an MX7000 :)
Which type of MX7000 is it ?? (type 33xx or 78xx), the combination of tv/remote and way of storing might be a problem...
