It is a D.I.Y. job - the DVD door comes off easily, there are two holes on the underside and you use them to release two clips with a thin-bladed screwdriver - look on the inside of the replacement door that you may buy and all will become clear. However you need a pair of service legs to perform a colour change with the aluminium surround. Screen off, the back off and hey presto! I can only assume that whoever gave the advice that it is cheaper to buy a completely new screen than to change the colour did not quite understand how the aluminium surround and DVD cover actually fit to the BV7 and wanted to sell you a new set!
Tools required: torx set, hex keys, service legs Estimated time: 90 mins for first try.
Easy or difficult? Well medium
Cheap or expensive? About £200-£250.
