'You live and you learn':....was working on a broken Avant 8420 with a suspected tube, it has the 'green fog' and stripes.
However, tapping didn't have any influence at all and the picture itself is still exellent...(many times with a bad tube it's not ok).
The better option for a good diagnose i guess is just to swap the cathode connections of 2 colours, by doing so i found out it is the tube after all.
So it seems not all faulty tubes are sensitive to 'tapping' it.... :)
