I could get a Philips PVR with integrated freeview, it´s named DTR7005. Is this particular model supported by the STB-C? If not, what´s your recommendation for a PVR with DVB-T? By the way: What´s the difference between the (older) STB-C and the (newer) PUC? Afaik the STB-C needs an IC to be updated, while updates for the PUC are made via a data port. Does Struer keep the STB-C still up-to-date at all or do they renew the PUC software only?
Thanks + regards, beoberlin
