1st March February 2012
Latest post 11-04-2008 8:49 AM by BeoIce. 9 replies.
10-27-2008 3:19 PM
patrikian
- Joined on 02-14-2008
- Posts 18
STB, Set Top Box controller for MX4000 / 4002 TV
Does anyone know where to get hold of a set top box controller for MX4000 / 4002 ? And does anyone have any experience from these - do they work OK? Thanks.
gk31ax
- Joined on 04-18-2007
- Posts 220
Re: STB, Set Top Box controller for MX4000 / 4002 TV
I have a STB working on my MX4000, I bought the controller on ebay, had it fitted by my dealer which cost around £100.
Works perfectly fine and is controlling a Sky box.....
BeoIce
- Joined on 03-27-2007
- Recklinghausen, Germany
- Posts 281
Sounds interesting. Is this item still available from B&O ? Do you have any part-no. for that ? Which type of MX4000 do you have ? Regards Martin
BeoSound 9000 MK III, BeoLab 6000, BeoLab 11, BeoCenter 2300, BeoSound Century, BeoVision MX4000/MX7000 & BeoCom 4
Samsung UE40B7090, Samsung HT-WS1G, Technisat HD8-S, Sony PS3, Logitech PS3 IR-BT-Adapter & Lintronic TT455-RT-238
stefan
- Joined on 04-16-2007
- 200 miles from Struer
- Posts 1,733
There is a stb controller for all MX TVs , 4000, 6000, 7...incl. AV 9000. Works also in old 2 way models. I have two in an MX 4000 and an AV 9000. They work fine. I don`t think that they are still available. I have no part no. - sorry. Stefan
mr_anders_son
- sweden
- Posts 1,032
I have one for sale item: 1403000
BeoIce
- Posts 281
What's about an MX4000 MKII ? As beoworld product information says a MX4000 MKII has type nr. 33xx. Will it work with this version too ?
Thanks Martin
BeoIce
- Posts 281
Does nobody knows for sure, if the stb-c will work in a MX4000 MKII Type-Nr. 33xx ? I could get one, but I want to be sure before bying it. Martin
Roger
- Joined on 03-28-2007
- Norway
- Posts 870
I would strongly recommend using a 2nd hand HDR-1 as the STB-C - this product can be updated via the service tool (a simple plug and play job) to cover new and coming boxes. And you can get an HDR-1 for a very good price these days as they are very difficult to sell (same goes for the HDR-2). And, yes, the mkII 3320-3339 can be used with the STB-C (you will need the lastest IC to handle newer boxes, and the chips are available from your local dealer). Roger
BeoIce
- Posts 281
Thanks for your answer Roger. I want to use a real old stb with the controller, a nokia d-box 2. Regards Martin
Page 1 of 1 (10 items)
