Latest post 10-30-2008 2:50 PM by tournedos. 3 replies.
Page 1 of 1 (4 items)
  • 10-27-2008 5:18 AM
    MX6000 bass drivers
    At least one of the bass drivers in my MX6000 has foam rot (didn't hear anything wrong, but I peeked with a flashlight). Are replacements still available new at any reasonable price, or am I better off refoaming the original pair? Can't be too hard given the rather small size...
    -mika
  • 10-27-2008 5:42 AM In reply to
    Re: MX6000 bass drivers
    Terve Mika,
    There have to be replacements available. And I can't imagine they would be too expensive. And if you can do the replacement yourself it should be expensive.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 10-30-2008 10:18 AM In reply to
    Hi Mika,
    There should be a 7 digit part code stamped on the back of the bass driver, which will allow your local B&O dealer to re-order the part for you.  Alternatively, you could check the Service Manual on BeoWorld, which should have a full parts list.  Let me know if you can't find it and I will try to locate this for you.
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
  • 10-30-2008 2:50 PM In reply to
    Thanks guys,
    I may check with the dealer about the pricing, but I'm afraid I might be too lazy to do anything after all. As I said, I can't hear anything wrong with the sound and if I want the best sound for a music program or something, I'll route it to the audio stack anyway...
    -mika
