Latest post 10-27-2008 8:03 PM by jk1002. 3 replies.
Page 1 of 1 (4 items)
  • 10-26-2008 5:39 PM
    Mac Pro and Beolab 2500
    I connected my two Beolab 2500 speakers to my Mac Pro (trying both the audio analog output on the rear and headphone one on the front) and nothing happens. The speakers are on (they have a small red light on the front) and I just bought the cables at a B&O shop here in Manhattan. They are two 8PIN DIN male/ RCA male cable connected to a minijack to Rca Us.
     I also tried to connect an iPod and a cd player. Nothing.
    Can someone help me? Thanks
    Emanuele
  • 10-27-2008 4:07 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Mac Pro and Beolab 2500
    Hi Emanuele,
    when you see red lights on the front the speakers are in standby mode. You will need a 5 V signal on pin 4 at the DIN connector to start them. The lights will turn to green and they should work. More info about powerlink: http://www.beoworld.org/beotech/misc2.htm
    Maybe you can get 5 volt via USB (?).
    Good luck
    Stefan
  • 10-27-2008 5:55 PM In reply to
    Thank you very much, Stefan. But I am not very expert: I have Usb ports on my display, for instance. Any suggestions on how to proceed?
    Thanks for your interest and your kindness,
    Emanuele
  • 10-27-2008 8:03 PM In reply to
    The Beolabs operate through powerlink. The 5 volt supply power would normally come from the stereo to keep the speaker powered on (green light).
    So you just need to replicate that. Your dealer may be able to help you, or you could just buy an external powerbrick and built a cable yourself.
    The layout you can find below
    http://www.beoworld.org/beotech/mclconn2.htm
    I am personally a big fan of talking to a dealer.
