Latest post 10-26-2008 5:22 PM by knoxit. 2 replies.
Page 1 of 1 (3 items)
  • 10-26-2008 2:35 PM
    • knoxit
    • Not Ranked
    • Joined on 10-26-2008
    • Posts 3
    Beomaster 6000 stuck at low volume
    hello. I have a Beomaster 6000 which is stuck at low volume. Pressing the volume buttons, I can hear the motorized volume potentiometer, but the level does not change. What could be the cause for this and how difficult is it to repair? thanks!
    Filed under:
  • 10-26-2008 3:20 PM In reply to
    Re: Beomaster 6000 stuck at low volume
    Very common problem with BM6000's. It will be the rubber belt that has stretched/come off. Openit up and replace the belt. Its not to difficult to do.
  • 10-26-2008 5:22 PM In reply to
    • knoxit
    • Not Ranked
    • Posts 3
    thanks for the advice. i will try that!
