Latest post 10-26-2008 3:33 PM by Lab5. 1 replies.
Page 1 of 1 (2 items)
  • 10-26-2008 2:34 PM
    Beocom 2 Won't charge
    I have a beocom 2 that won't charge, i Have cleaned the contacts on the bottom and when i put it in the base, the Logo comes up briefly as if charging but then goes off. Could it be the battery or the contacts, the base is fine as it charges my other Beocom 2. Is it possible to removed the bottom of the phone?
    Filed under: ,
  • 10-26-2008 3:33 PM In reply to
    • Lab5
    • Top 500 Contributor
    • Joined on 02-07-2008
    • Posts 231
    Re: Beocom 2 Won't charge
    i dont think its the base it seems to be the battery oder the cables from the bottom of the bc2 to the battary inside of the bc2.
    you have to open the bc2  and look inside!
    godd luck
    BV7 40 MKIV Black an 4 Beolab 8000 mit Beolab 11 Beolab 7-4 ne BS9000, BM5, 2 BC 6-23 in gold, 2* BV 3-32 an Beolab 6000 , 2* BV3-28, 5 Beolab 3500
