Latest post 10-26-2008 8:55 AM by Alex. 7 replies.
Page 1 of 1 (8 items)
  • 10-26-2008 5:00 AM
    Beolab 6000s
    Hi.
    I wonder if I am on my own here but im rather disappointed with the sound quality of my BL6000s....I initially thought it might be a problem with the particular pair but i have a second pair and they sound the same.
    I find them to be very bass light ( I cured this with the addition of a Gallo Subwoofer ) but the main problem I find is lack of imaging and general excitement
    I am running them through a Beocenter 2300 and im wondering if a change to BL8000s or even Lab1s will be worthwhile ( although id rather not spend a heap of money at the moment.
    Simon
  • 10-26-2008 5:58 AM In reply to
    Re: Beolab 6000s
    I'm afraid that the lab 6000 are a bit too much about appearance and a bit too less about sound quality. Stylish, but sadly not very good.
    The lab 8000 are in my opinion pretty good.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 10-26-2008 6:01 AM In reply to
    Re: Beolab 6000s
    Hi ,
    Do you have only BL6000 ? Cos usually they where used like rear speakers or for saround setup or like additional speaker.
     They have lack of deep  bass  on low frequency, but in my opinion they produce really detail sound.
    Of course BL8000 is much better speakers!
    May I suggest  to put additional pair of BL4000 (really  good speaker) and see what will happen. BL4000 is much more cheaper than BL8000, and if you dont like it you always can move them to other room.
    Hope it helps Smile
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
  • 10-26-2008 6:20 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Re: Beolab 6000s
    Yes see if you can try out 4000's they are incredible, BL1 may be the best... but see how you go.
  • 10-26-2008 6:27 AM In reply to
    Re: Beolab 6000s
    Consider 4000s as suggested above. More bass, especially if wall mounted. I really like them - more internal volume - a thoroughly splendid small speaker.
  • 10-26-2008 7:26 AM In reply to
    • Dave
    • Posts 2,328
    Re: Beolab 6000s
    Peter :
    Splendid speaker full stop! Big Smile
  • 10-26-2008 7:46 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Beolab 6000s
    Ask your dealer if you can try the different speakers, in your own home. I'm sure a good dealer will be happy to oblige.
    Andy T.
    Poor me, never win owt!
  • 10-26-2008 8:55 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Beolab 6000s
    If excitement is what you're after, then maybe BeoLab 3s will deliver more for your taste. I find them to be more snappy, detailed and 'fast-paced' than 6000s, 4000s or 8000s. Imaging is stunning, mainly due to the Acoustic Lens.
     Weekly top artists:
