Latest post 10-30-2008 6:09 AM by Xseries. 1 replies.
Page 1 of 1 (2 items)
  • 10-25-2008 2:08 PM
    • Andy
    • Top 500 Contributor
    • Joined on 07-24-2007
    • Melton Mowbray
    • Posts 128
    US Beocord in UK
    Hi
    I have a beocord from the US with a US plug using it in the UK I have purchased a step down transformer it can handle a 100 W output. The Beocord works fine apart from a very loud hum..... earthy hum! This can be heard when the beocord is switched off through the amplifier. When disconnected from the mains the hum disappears. Can anyone suggest how to get rid of the hum. Do i need to ground the unit in any way.
    The US plug is a 2 prong type
    Andy
  • 10-30-2008 6:09 AM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Re: US Beocord in UK
    Which Beocord?
    Some of the models have a transformer that can be readily modifed (ie re wire a lead to the transformer) to take account of 220 / 110 volts which may be a better way forward .
    Brian
