The trimmer has fallen apart, replace it - and and oterh trimmer of the same type - and readjust to factory specs.
The garbled display is a different issue, not related to neither the motor/belts nor the trimmers. Check that all cables are on correctly and the connections between the display and sound control boards are good.
