1st March February 2012
Latest post 10-25-2008 10:18 PM by PhilLondon. 6 replies.
10-24-2008 2:05 PM
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
I have one pyramidal base station and 2 handsets. Since the 23rd of September, none of the handsets register missed calls and recent calls. When I press redial, I still see the people I called on the 23rd last month. Same when I press Caller ID. What may have happen? I suppose it is the base as both handsets react in the same way. I can still store numbers... p.
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
When the phones rings, can you see the number calling you?
Daniel
- Svinarp, Sweden
- Posts 1,284
OK, then I've got no clue. Sorry!
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
A hard reset is always worth a try. Unplug the PSTN base for 10 minutes and see if this makes a difference. I've had a few anomolies with my Beocom 6000 which were solved by doing this. Chris.
Opman
- Joined on 12-31-2007
- Cheshire, UK
- Posts 323
When you unplug the base from the mains, switch the handsets off as well. Then re-connect the mains first, then switch the handets back on. I find that usually helps the handsets to re-establish connection ot the base. The mark 1 handsets are switched by holding down the "dot" button to the left of the wheel for about 7 seconds until the display says "power off". To switch the handset back on, just press the dot button again. Opman
PhilLondon
- London
- Posts 2,545
It has done the trick! Thanks!
Page 1 of 1 (7 items)
