Latest post 05-17-2007 4:01 AM by moxxey. 7 replies.
Page 1 of 1 (8 items)
  • 05-16-2007 1:43 AM
    BeoVision 7 32" darkens the picture too much
    I have noticed that my BeoVision 7 32" I have bought used (1,5 years old) darkens the picture during dark film scenes even more than it should. This happens mostly when subtitles are displayed otherwies not. Does somebody have the same problems?
  • 05-16-2007 2:31 AM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Re: BeoVision 7 32" darkens the picture too much
    avus17:
    Yes, this is very much a problem on older BV7's. My old 2004 model is very 'gloomy' looking, particularly when watching dark DVDs. My local dealer lent my a brand new BV7 recently, for a month, and the picture was brighter, lighter and sharper. I saw a major difference when I went back to my old panel :-/
    I guess your second-hand BV7 is similar to the above. With the new model due this year, this will improve the panel even further.
  • 05-16-2007 2:40 AM In reply to
    Do you know if this problem can be solved somehow?
  • 05-16-2007 4:15 AM In reply to
    • GSHaigh
    • Top 500 Contributor
    • Joined on 04-16-2007
    • North West UK
    • Posts 163
    If your set has had the HD upgrade done then there is a setting in the system menu to switch auto-backlight off, this fixed the problem on my old BV7.
    Greg
  • 05-16-2007 9:20 AM In reply to
    Hello Greg, I have the HD upgradeed BV7, can you tell me how the backlight in the system menu can be switched off?
  • 05-16-2007 2:01 PM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    you can access the service menu with  0 0 GO, but be carefull!
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 05-17-2007 1:47 AM In reply to
    Can you tell me what happens if I press 00 GO are there service menus where I can see how to turn off the backlight?
  • 05-17-2007 4:01 AM In reply to
    • moxxey
    • South West, UK
    • Posts 2,360
    avus17:
    No, this isn't a problem with back-lighting. It's purely the quality of the (now old) LCD panel. The newer BV7 panels have an improved refresh rate, brightness and contrast levels. I noticed that the panel just appeared around 25% brighter than my old BV7. It's not a 'problem' as you mention - it's the TV and the panel used.
