1st March February 2012
Latest post 11-02-2008 5:51 PM by ipaul. 16 replies.
10-23-2008 1:42 PM
wasti
- Joined on 08-29-2008
- Cracow, Poland
- Posts 112
How much are the Beovox 2500 Cube nowadays worth? In good overall condition. How much are these loudspeakers worh for you?
It would be lovely to have them! :) Regards PS. BTW, is there any possibility to get inside the cube? To replace a tweeter? I could not find a service manual at BeoWorld though.
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
Value depends on condition, but they do seem to command a very high price regardless. Around £250 for average ones and anything over £500 for mint. A couple of years back a pair of mint condition ones sold for over £1,000 - which was ridiculous to be honest. The tweeters are each held on with 4 screws (one in each corner) into the wooden block which forms the cube, access is by removing any of the tweeters - nothing at all complicated about these. The tubular stand is simply pushed in and helb by machined grooves & possibly some sort of glue. Chris.
wasti
- Cracow, Poland
- Posts 112
Thank you Chris for your reply. I can imagine why the Beovox 2500 reach so high prices nowadays. I have been hunting for two months for these loudspeakers on ebay and still with no luck.
It is quite funny when you compare the '70 prices to the present once of Beovox 2500. 50 GBP for new and now over 500 GBP for used once! I guess I will post a new topic on the forum on this fenomen. Best regards,
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
wasti: It is quite funny when you compare the '70 prices to the present once of Beovox 2500. 50 GBP for new and now over 500 GBP for used once! I guess I will post a new topic on the forum on this fenomen.
But Britain had very heavy inflation in the 70s, and the value of money has changed a lot. 50 pounds in 1970s money would have had about the same purchasing power as 500-1000 pounds today! So the cubes wouldn't have been such a winning investment after all
Medogsfat
- Posts 4,045
To be brutally honest they are pretty useless unless you have the correct set up for them (beolab 5000 system). I had a pair in fairly good condition which I bought purely on looks and to me they ended up as being no more than very pretty paper weights! I did play them on their own just the once and they almost caused the wax in my ears to melt - "yodelling stick insects" is the phrase that springs to mind! I have to admit that when they do appear on ebay I am always tempted to bid on them as they are just sooo cool looking I sold/swapped them to member casdave for the equivalent of @ £100 a few years ago as I knew he had the Beovox 5000's to match them. A happy outcome for both of us I agree 100% with Mika, £50 was a very good weeks wages in Britain back in the 70's. Chris.
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
wasti: I am astonished. Does it mean Chris that I cannot use the Beovox with any sound system without having the beolab 5000? This cannot be true ;(
Please advise.
The Beovox 5000's have a connection on the rear for the Beovox 2500's, as do the older type Beovox 3000's Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
Medogsfat
- Posts 4,045
Not exactly, but you do really need compatible speakers - as Craig has mentioned - with the extra DIN output to connect these to. The 2500's were really designed to enhance the high frequencies of certain speakers and by all accounts they do a very good job. I tried connecting mine to the speaker 2 outputs of my Beomaster 5500 to use with some RL60.2's and the results were quite bad - well horrible if the truth be known. They really are very very limited as far as usability goes but don't let that stop you buying some, IMO they are probably the best speaker investment you will ever make - certainly better than sticking your money in an Icelandic bank at the moment. Chris.
casdave
- Joined on 04-16-2007
- Posts 226
Hello Chris, Andy now has them, along with the relevant system, so they are getting around a bit, I suspect that's where they will stay for quite some time too. As for the compatible speakers,Beovox 5000, Beovox 4000, Beovox 3000, Beovox 1500. The 3000 - especially the first version - and the 4000s are quite rare, much more difficult to find than the 5000.
auric
- Posts 357
I saw these things in MOMA in NYC years ago. I only learned through this thread that they were designed to be used in addition to Bevox 5000 speakers. This is interesting because this must have been one of the earliest "satellite" systems. Note that they are omni direction and cube shaped; surely this must have been an inspiration for Bose's AM-5! Of course Bose made a fortune on the concept and hardly anyone is aware of B&O's contributions.
tournedos
- Finland
- Posts 5,808
auric:This is interesting because this must have been one of the earliest "satellite" systems. Note that they are omni direction and cube shaped; surely this must have been an inspiration for Bose's AM-5!
Another famous omni-directional concept is Grundig Audiorama (full range spheres) from the 70s, and though having seen neither "live", I have to say I like them quite a bit more than Beovox 2500. They are actually available new again!
ipaul
- Joined on 04-22-2007
- Posts 378
The Grundig version of the cube :) If you're looking for Vox 3000's you might try checking German second hand products sites (other than ebay), here in NL once in a while they pop up and sell for very little money (i have 2 pairs here, 1 set painted unfortunately and the other recently bought with 2 cubes with a missing shield for 30,- euro !!). The only trouble with the cubes is finding an undamaged pair, apart from that they pop up regularly on the internet sale sites.
Page 1 of 1 (17 items)
