1st March February 2012
Latest post 10-27-2008 3:03 PM by Medogsfat. 23 replies.
10-23-2008 4:44 AM
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
I need a pair of passive speakers and BeoVox 1 doesn't fit. A pair of CX's would be perfect, but is it safe to buy a pair? They're after all 15-20 years old. Will they sooner or later get foam rot etc.? Can I hear or see if this has happen or about to start?
Alex
- Joined on 04-16-2007
- Bath & Cardiff, UK
- Posts 2,990
If they've got foam rot, then I would hardly pay anything for them at all unless the cabinets and grilles are in mint condition. From a personal viewpoint, they're worth the £80 the drivers will cost you overall.
I would maybe pay £20 max for a 'knackered' pair, costing £100 overall once you add in the drivers. I've got a set of CX100 drivers sat beside me right now waiting to be fitted...
Weekly top artists:
Daniel
- Svinarp, Sweden
- Posts 1,284
But will they all get foam rot sooner or later, or is it safe to buy a pair without foam rot?
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
They will all get foam rot, sooner or later. It's safe to say that all CX50's and CX100's that haven't already had drivers repaired or replaced will have foam rot now. Martin
Dillen
- Posts 5,008
The only drivers that will work are the originals. Your dealer will be able to get order them for you. If not, go to a different dealer. Some B&O dealers won't sell parts. I can't buy anything from my local dealer either, they won't even answer my mails.  Martin
cooldude
- Joined on 03-14-2008
- Posts 971
Hi there, Indeed B&O dealers will not easily sell you spare parts. It's how they make most of their money,doing the repair and charge you not only for the spare parts but also for the work..... Off course at B&O type of rates.... Anyways, I have succesfully restored plenty of these now, and refoaming the original drivers is not all that difficult. I have tried (unsuccessfully) to find matching drivers but the specs seem not that easy to match. After trying a pair of refoamed speakers and a pair with new (B&O installed) drivers, the difference is quite minimal. Given the price of the refoaming (bit of glue and the new foam rings) I really don't see the need to install new drivers if it can be avoided. Updating the crossover is a more important issue imo and will make a difference. Also something not that difficult to do. Given the choice of cx50's and cx100's go for the 100's, they are worth the extra bit of money. However, I live in a rather small appartement and my surround system (av7000 ....) is hooked up with 5 cx50's (all reconditioned by me.) and they sound really great with a small sub (under the coach...nobody even knows it's there.). It easily outperformed the bose system I had before. Great clear and warm sound and less metalic than the bose.... They are used every day for 5 to 6 hours (I work from home anyways...) with complete satisfaction. Regards, Cooldude
ipaul
- Joined on 04-22-2007
- Posts 378
Imho going for 'the best' option is buying a nice pair with foam rot and get new original drivers, not the cheapest option but your CX's will be as good as new and last another 15 years and you know there hasn't been 'fiddled' with. Cheap option is buy with foam rot and replace foam rings yourself, personally i'm not too keen on it reading above 'the difference is quite minimal' but it does save quite some cash. Nowadays buying used CX's with good drivers could be tricky if you can't tell if the drivers are replaced with originals or 'the cheap way' which could make the CX's overpriced. The drivers (original B&O) used to be about 25 euro each so that's not 'unfair'.....
cooldude
- Posts 971
Off course it's best to replace them with new drivers, I agree. But I think you have to consider costs involved; The problem I have is that : 1) My B&O dealer does not want to sell me the drivers unless he does the job of installation as well. 2) the drivers themselves were quoted quite a bit more than the 25 euro you mention (over 80$+tx/pc for the part(driver) itself)..... let alone the price for the work charged for replacement. Just not worth it for me to spend over 350$ to have a pair of cx100's updated... But this could be a north american thing and pricing for a repairs in europe might be totally different. I have put my refoamed ones next to a pair with new (B&O installed) original drivers and they sound pretty close. Very hard to tell them apart. both use exactly the same crossover so the audible difference is only created by the drivers themselves. Off course I have to agree refoaming is a job that requires some knowledge. But for the person who wants to give it a go, there are plenty of sites with good info on the web. I have refoamed well over 100 speakers now (50+ B&O) so I would say that I can do a decent job of it.
Daniel
- Svinarp, Sweden
- Posts 1,284
Hi all! Considering the cost of either a restored pair or a unrestored pair plus the restoration cost plus the cost for a BeoLink Passive it will be cheaper (and maybe better sounding) with a used BeoLab 2000. It's what a suspected. Pitty, I wanted the CX's but not at that much money.  Thanx for the help!
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
I got mine from ebay in perfect condition (don't know if updated at all), for 100 Euro + shipping. So if you keep on looking there might be a bargain out there. The ebay listing wasn't too good, I e-mailed for photos. Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
Daniel
- Svinarp, Sweden
- Posts 1,284
OK, so it's time to update your signature?
dko7113
- Joined on 09-04-2008
- Copenhagen, Denmark
- Posts 104
Hi Daniel, www.radioogtveksperten.dk sell "new" drivers for DKK 350 each if you hand over your old ones: http://radioogtveksperten.dk/tilbehoer-44/modul-66/hoejttalerenheder-67/ I have delt with him a few times, and I am very satisfied. Regards, Erik
My Beo: BeoCom 6000, BeoCom 2500, BeoCom 1401, BeoLine, BeoVision LX6000, BeoVision LX2500, BeoVision MS6000, BeoVision MX4002, BeoVision MX1500, DVD1, BeoSound 3200, BeoSound 1, BeoLab 4000, BeoGram 4500, BeoPort, BeoPlayer, 3x Beo 4, 2x BeoLink 1000, V Terminal, Form 2, Light Control 2, BeoTime
kallasr
- Posts 1,077
Daniel:OK, so it's time to update your signature?
Done! Ralf
Steve at Sounds Heavenly
- Joined on 05-18-2007
- In the cable workshop, Melton Mowbray, UK
- Posts 356
Hi everyone, No promises at this stage, but I'm in the process of trying to get a replacement mid/bass driver made for the CX50/100 that has a rubber cone surround. I've struggled to get the full spec of the original speakers out of anyone at B&O, but I think I have enough data to work with now. It could take a few months before this becomes a reality, not least of the problems being the need for a custom sized spider, due to the small cabinet entry hole and compact size of the grilles. I will, of course, keep you all updated on my progress, if this is of interest to anyone on Beoworld? As a CX "addict", I've replaced and refoamed too many drivers in the past to want to keep repeating the process, so I'm keen to find a "once and for all" solution even just for my own use. However, I suspect that manufacturing economies of scale will mean that I need to order a large quantity and sell the rest.... Best regards, Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
CX speakers are worth every penny if you are stuck for space, refoaming them is easy peasy compared to most other drivers. Comparison with replacement drivers is not exactly a controlled science as new drivers will need a fair few playing hours to "run in" and may well sound just the same as refoamed ones in a few months time in any case. Chris.
Medogsfat
- Posts 4,045
It used to be 8480174 but it has changed a couple of years ago. This is the part number for the bass driver only, the mid range is 8480173 but these are no longer available and B&O tend to just supply the bass driver nowadays to replace all 4. Chris.
stotty1111
- Joined on 12-16-2007
- UK / France - Nth Worcestershire/Finistere
- Posts 924
hi there i have just refoamed the 4 from a pair of cx100's got the rings by return of post from good hifi of amsterdam(i think!) do a search on ebay they have various prices advertised for the same ring a bit tedious to scan 'em all but you could save several euro think i paid about 12€inc post about 10 weeks ago! hope this helps! salut tony s
I always try to operate using/following the KISS principle -- Keep it simple stupid!
Medogsfat
- Posts 4,045
Agreed! good hi fi in the Netherlands sell the best fitting surrounds I've found for these. Chris.
Page 1 of 1 (24 items)
