Latest post 09-23-2007 3:06 PM by pjono2003. 2 replies.
Page 1 of 1 (3 items)
  • 05-15-2007 5:29 PM
    HELP!- SET TOP BOX CONTROLLER CODES FOR CURRENT SAMSUNG NTL BOX
    Anyone managed to find a compatible set of codes for this unit. I've tried the old Pace NTL option but it doesn't doesn't function. Can't be alone here can I??
  • 05-15-2007 6:39 PM In reply to
    Re: HELP!- SET TOP BOX CONTROLLER CODES FOR CURRENT SAMSUNG NTL BOX
    The only Samsung  codes I can find are 27, 58 or 74. Worth trying I suppose! The Pace NTL boxes are 10 and 11.
  • 09-23-2007 3:06 PM In reply to
    Hi, WIll you let me know if you manage to sort this as I have the same problem. I heard there's a firmware upgrade that has extended options which may or may not includethis unit codes. Don't know whether this is the case
    regards
    PJ
