Latest post 10-24-2008 2:38 PM by Friedmett. 6 replies.
Page 1 of 1 (7 items)
  • 10-20-2008 5:40 PM
    Wanted - beolink 1611 converter!
    As above!
    Thanks,
    Llewelyn :-)
  • 10-23-2008 11:27 AM In reply to
    Re: Wanted - beolink 1611 converter!
    i believe i may have a pair of these boxed up somewhere.
    i will have to confirm they are 1611's and not another type.
    also, they are us120v -where are you located?
    • B&o bottle opener
  • 10-23-2008 2:36 PM In reply to
    Hi Burantek
    I am actually in the UK so would need 220v euro ones!
    Thanks anyway
    Llewelyn Smile
  • 10-23-2008 2:43 PM In reply to
    very well, sorry.
    good luck w/ your search -if you have no luck, and wanted to throw it on a transformer -LMK
    • B&o bottle opener
  • 10-24-2008 8:07 AM In reply to
    I got one 220volt which I have no use for.
    It came with Beovision LX5500 along with a 1615 video and a bunch of link cables.
    To make it useful with UK plugs you have get the powerlead by a dealer unless you can use the Danish one.
    Make me an offer.
  • 10-24-2008 2:05 PM In reply to
    Hi
    Having done some research it seems I am actually looking for a Beolink Video instead! I need it for linking an Avant to an MX4000, and was under the impression that a 1611 would do it - However it seems that the 1611 can only handle audio IR so I am now looking for a Beolink Video instead!
    Best wishes
    Llewelyn Smile
  • 10-24-2008 2:38 PM In reply to
    Well I have no use for my 1615 either.
    I can take some pictures if you want.
    Make me an offer.
