1st March February 2012
Latest post 01-23-2009 7:57 AM by nmartin771. 18 replies.
10-19-2008 6:17 PM
nmartin771
- Joined on 02-18-2008
- Novi Sad, Serbia
- Posts 3,103
Hello, one simple question. Today I received my Beocenter 1 and I have also Beocenter 2300. When I press radio button on my Beo4 both radio is turning on.... How can I turn on only one radio with my Beo4? Thanks
when your Black Label begin to taste like juice just take shot or two of Absinthe and
after that quench with some vodka, if you still feel juice like take beer
with grappa !
Alex
- Joined on 04-16-2007
- Bath & Cardiff, UK
- Posts 2,990
Standing next to the BeoCenter 1, push:
Standby + List at the same time
Use up + down buttons until OPTION? is flashing on remote display.
Push Go
Do the same until V.OPT? is flashing on remote display.
Push Go
Push 1
This should stop the BeoCenter 1 from responding to the 'Radio' command, assuming this is what you want to happen.
Weekly top artists:
nmartin771
- Novi Sad, Serbia
- Posts 3,103
Thanks Alex, And than how can I turn on RADIO on BC1 ?
with grappa !
PhilLondon
- London
- Posts 2,545
This solution would not work if all speakers were connected to the BC1. I believe there is another way to do it with the BC1. I remember seeing it on this forum. I do not know if it is in the standard menu or in the hidden menu. p.
nmartin771
- Novi Sad, Serbia
- Posts 3,103
My speakers are not conected with BC1. BC1 is stand alone and BC2300 is connected with speakers. So my problem is how can I control wich device to turn on? Of course I dont want to disable radio on BC1. Thanks
with grappa !
PhilLondon
- London
- Posts 2,545
In that case that would work. RADIO would turn the BS 2300 on. AV + RADIO would turn the BC1 radio on. Why have you not connected the 2, do not want to listen to the TV sound on the BS speakers sometimes? p.
nmartin771
- Novi Sad, Serbia
- Posts 3,103
Aha I see, So that setup Alex told me will work this way RADIO-bc2300, AV+RADIO - bc1 ? I didnt connect BC2300 with BC1 cos tv has outstanding sound !
with grappa !
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
How cool is the BC1! I think you got the same one as i did, on the tall stand from Lifestyle AV? The sound is pretty good mainly when it's turned up loud. The AV + Radio pressing on the Beo4 should fix your problem... yoou should link them with master ink so they work together, you still enjoy the sound from the telly - masterlink is really quite clever.
PhilLondon
- London
- Posts 2,545
Do you have ML and Powerlink at the back of your BC1, Martin? Are you using the Beo4? Which speakers have you got? p.
nmartin771
- Novi Sad, Serbia
- Posts 3,103
Phillipe, Now I'm using BC2300 with Marantz 1050 - year 1972, and Bose acoustimas 10 speakers. I'm planing to buy BL4000 and BL6000. On my BC1 I have almost every option available with Dolby back, so I have ML and Powerlink. And yes I'm using Beo4. BC1 picture and sound is outstanding
with grappa !
PhilLondon
- London
- Posts 2,545
Like Dave, I would recommand that you link the two together. You need a Beolink converter and a masterlink cable as well as a datalink cable, and a fully cabled powerlink cable. I would also connect all speakers to the TV. The downsides of this suggested configuration: - Loss of 2 way remote control, but it is not a problem for you as you have a Beo4 - No possibility to start an audio recording manually, but you have no tape. - Loss of the Aux socket on your BC2300, but you can always connect a audio device on a Scart socket. You'd get a better integration. You'd still get the sound of the TV on the TV speaker but you'd be able to turn the external speakers as well. When you get extra speaker, you may want to install some link rooms as well. This new setup is more ready for it. p.
nmartin771
- Novi Sad, Serbia
- Posts 3,103
Aha, I see Thanks for info Philipe ! Why not I will try it . But I want to conect iMAC via Aux on my BC2300
with grappa !
nmartin771
- Novi Sad, Serbia
- Posts 3,103
PhilLondon:
p.
I'm waiting for BL8000, and I will do exactly how you told me. Bs2300 - converter 1611 - materlink BC1. BC1 - BL8000
But I'm interested how I make setup work ?
I heard that I need to setup TV for OPTION 2 and BS2300 OPTION 0 ? Is this correct ?
I want to listen radio from Bs2300 - when I press radio on beo4 to turn on BS2300.
And how I change speakers when I watching TV ?
Uh.... to many questions :)
with grappa !
nmartin771
- Novi Sad, Serbia
- Posts 3,103
Is this right way
BC1 TV OPTION 2 and BS2300 OPTION 0 ?
with grappa !
Dave
- Posts 2,328
nmartin771
- Novi Sad, Serbia
- Posts 3,103
Thanks Dave,
Are you satisfied with your BC1 ?
with grappa !
Dave
- Posts 2,328
Oh yes very much so, i love it and i couldn't be happier :)
It's my bedroom television and fulfills it's role to a tee - especially being on the unique tall pole stand
Page 1 of 1 (19 items)
