Latest post 10-21-2008 2:51 AM by -multimedia Robert-. 8 replies.
Page 1 of 1 (9 items)
  • 10-19-2008 3:41 PM
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    BeoLink Converter - BM6500/7000 and New TV
    I wonder if anyone could help - if you were connecting a new TV to an older BM6500 or BM7000 (via a Convertor) would you connect the powerlink speakers to the TV or the 6500/7000?  Would that be influenced if you watch more TV or listen to more CDs / vinyl??
    Thanks for any help!
    Confused!
  • 10-20-2008 9:07 AM In reply to
    Re: BeoLink Converter - BM6500/7000 and New TV
    You would normally connect your powerlink speakers to the TV and the 6500/7000 via a Type 1611 converter.
    It makes no difference which unit you use most.
    Regards Keith....
  • 10-20-2008 9:34 AM In reply to
    The downside of connecting the speaker on the TV, is that you lose 2 way control of the BM.
    It still remains the recommanded solution.
    p.
  • 10-20-2008 10:28 AM In reply to
    • stefan
    • Top 50 Contributor
    • 200 miles from Struer
    • Posts 1,733
    I heard there is a special sw 1.3 for BM 7000 that will give you 2way-communication even in option 0.
    Stefan
  • 10-20-2008 5:04 PM In reply to
    • Xseries
    • Hampshire
    • Posts 433
    Where could I obtain sw 1.3??
  • 10-21-2008 2:00 AM In reply to
    I can confirm what Stefan has stated.
    Version 1.3 provided what B&O called a special "option 0"
    Your Beolink 7000 will be setup for two way remote for audio and one way for video.
    You may find that you can still purchase it through a B&O dealer and it has a part number of  8342830 and is 4IC2
    Regards Keith....
  • 10-21-2008 2:12 AM In reply to
    Any similar upgrade for Beocenter 2500?
  • 10-21-2008 2:19 AM In reply to
    I do not think so...
    Regards Keith....
  • 10-21-2008 2:51 AM In reply to
    Keith Saunders:
    Hi All,
    I asked my dealer this year about the costs for this part, I was told it is 45 euro.
    See also this topic for possible restrictions in operation!
    http://forum.beoworld.org/forums/post/72126.aspx
    Regards, Robert
