Latest post 05-17-2007 12:22 PM by Peter. 15 replies.
Page 1 of 1 (16 items)
  • 05-15-2007 2:46 PM
    AV 7000 interface with Beosound 9000
    Hello all,
    I'm new to the forum and really need some help. I've slowly gotten my BO equipment and need some HELP !!! please..
     I've got the following and am looking for the best (neatest) way to interface it all.
    The ability of the AV 7000 is my biggest question. ie. does it have an amp for the center speaker? can i loop the center speaker outs (if preamp) back to my tv and use that speaker.?? can i make the 4 BO speakers work as surround when i like, THEN change it to just 4 speaker stereo?? Sorry for all the questions...i really need some help here !!! THANKS AGAIN ...
     1) 2 beolab 8000 speakers
    2) 2 beolab penta I's speakers
    3) beosound 9000
    4) AV 7000 processor.
  • 05-15-2007 3:16 PM In reply to
    Re: AV 7000 interface with Beosound 9000
    Is there a thread talking about the AV 7000???? thanks.
  • 05-15-2007 3:29 PM In reply to
    The AV7000 was a US only model and hence the European members will have little experience of it. I think there is an amplifier for the centre speaker built in and the other speakers use Powerlink. Mark 1 Pentas will need the special cables.
  • 05-15-2007 3:50 PM In reply to
    Peter,
     Can I run Powerlink cables to the penta 1's and then convert at the speaker to the Speaker link?? We're putting wires in the walls so if i go with Powerlink in the walls I can change speakers in the future if necessary...thanks,keith
  • 05-15-2007 3:54 PM In reply to
    The straight answer is yes. I would suggest using fully wired Powerlink cables as these will suit all speakers!
  • 05-15-2007 10:14 PM In reply to
    • beotex
    • Not Ranked
    • Joined on 04-20-2007
    • USA
    • Posts 32
    mecca:
    Welcome to the forum. Yes, the AV7000 has an amp for the center speaker, but I don't know if you can loop it back to your TV. You should be able to choose Speaker 4 or Speaker 5, which will allow 4 speaker stereo or surround sound. I had one hooked up to a Beosound 9000, and I believe I had to use a BoLink Converter (1411) to connect the two. Hope that helps.
  • 05-15-2007 10:22 PM In reply to
    Thanks beotex,
     Any idea where i could pick up the beolink converter that i need to interface these 2??? and how much it is?? thanks for the help and welcome..
  • 05-15-2007 11:42 PM In reply to
    Important question on the AV 7000:    Are the active speaker outs in Powerlink or Speakerlink????  Thanks.
  • 05-16-2007 1:44 AM In reply to
    Powerlink. The  Beolink converter is about £120 but you should be able to get a cheaper one second hand. Unfortunately they are voltage specific so a UK one will be of little use.
  • 05-16-2007 10:00 AM In reply to
    Thanks Peter. I'm trying to find a us model now.
  • 05-16-2007 5:44 PM In reply to
    There is one right now on Ebay.com . It is quite expensive though with 600$. Normally you can pick them up way cheaper.
    Be warned, an US dealer made a funny coment about it on the old beoworld so it might be better to skip it and try getting a used beosystem.
  • 05-16-2007 5:51 PM In reply to
    jk1002:
    I take it you mean an AV7000 for $600! The Beolink converters go for about £30!
    I certainly would not recommend an AV7000 for anyone outside the US. But they do fill a need there.
  • 05-16-2007 8:54 PM In reply to
    We'll know soon, picked up a AV7000 for $325 on ebay a few days ago supposed to be in "like new" condition...just found a converter new (OLD) in box from a previous dealer but it's $300 uggggg....getting all the cables togther...i need a long masterlink and some real long powerlinks......anyone???? thanks to all for the help so far..
  • 05-17-2007 1:58 AM In reply to
    Make sure it is the correct converter!
  • 05-17-2007 11:16 AM In reply to
    Hi Peter,
    The converter I found and I "think" is correct is the:  Bang & Olufsen 1161266
     Is this correct??? Thanks a ton for all your help Peter..
    Keith
  • 05-17-2007 12:22 PM In reply to
    That sounds like the right one. $300 is the new price though!
