Like explained in another thread, I am trying to define some functions and macros for the DVD2. Unfortunately it seems like my DVD2 (configured as CDV/DVD-source on an Avant) can only be accessed by the Beo5 using combinations of 2 IR-codes BEO4EX_COMB_<number> + BEO4EX_COMB_<number> as there is no possibility to choose CDV/DVD as target unit in the IR code menu.
When I decided to purchase the Beo5, I thought the programming of the DVD2 would be much easier, e.g. choosing "DVD" (or "CDV") as target unit an then using the codes for the Beo4-keypresses (numbers, color keys, ...). But the usage of these IR-code-combinations makes it very difficult for me to get out how to programm the Beo5 correctly.
I was able to look up the IR codes for the following functions, which where predefined in the template of the Beo5-Configuration-Tool:
- Disc-Menu: 0:000:TV:BEO4EX_COMB_3+BEO4EX_COMB_2
- GuidePlus: 0:000:TV:BEO4EX_COMB_3+BEO4EX_COMB_6
- GuidePlus->Timer: 0:000:TV:BEO4EX_COMB_4+BEO4EX_COMB_5
- Channel +: 0:000:TV:BEO4EX_COMB_3+BEO4EX_COMB_7
- Channel -: 0:000:TV:BEO4EX_COMB_4+BEO4EX_COMB_1
- HDD-Content: 0:000:TV:BEO4EX_COMB_3+BEO4EX_COMB_1
- last channel in history: 0:000:TV:BEO4EX_COMB_4+BEO4EX_COMB_7
- next channel in history (if last channel button was used before): 0:000:TV:BEO4EX_COMB_5+BEO4EX_COMB_1
- Info Menu: 0:000:TV:BEO4EX_COMB_3+BEO4EX_COMB_5
- System Menu: 0:000:TV:BEO4EX_COMB_4+BEO4EX_COMB_2
- TV/HDD switch: 0:000:TV:BEO4EX_COMB_4+BEO4EX_COMB_3
- Edit: 0:000:TV:BEO4EX_COMB_3+BEO4EX_COMB_3
But I am still missing the following functions:
- Enter/Return in GuidePlus-Menu (Beo4: 2x Go)
- Stop the TV programm and start to record (on Beo4: STOP, then red key)
- ...will be continued soon... (saturday)
Currently I don't see any relation of the combinations listed above to the button hits that I am using on Beo4 to access these functions on DVD2. Therefore I am not able to complete my list of codes.
Can you help me finding out the logic behind these combinations or do you know the missing codes for the functions listed above? A documentation of the IR code set might also help but typing "BEO4EX" into Google did not lead to usable results.
Thank you very much in advance for any help or hints.
