Latest post 05-15-2007 9:15 PM by sunit. 4 replies.
Page 1 of 1 (5 items)
  • 05-15-2007 2:03 PM
    • sunit
    • Not Ranked
    • Joined on 05-15-2007
    • Posts 2
    Need help connecting BEOLAB 4000 to BEO 3200 using two wire cables, can it be done?
    Hi
    I have two copper wire cables running in my house can I connect BEOLAB 4000 to BEO 3200 using these cables or do I have to pull the B&O provided cables around.
    If I do cut the B&O cables they have three wires running which of those two should I use
    Sunit
    Filed under:
  • 05-15-2007 2:29 PM In reply to
    Re: Need help connecting BEOLAB 4000 to BEO 3200 using two wire cables, can it be done?
    The most satisfactory way of connectiong is with B&O power link cables which have multi pin din connectors. I suspect that these are not the B&O cables that you mention as they have more than 3 conductors.
    I could just about imagine a system which would work using powerlink/rca adaptor and your existing cables but this would be an absolute last resort.
    Regards Graham
  • 05-15-2007 2:34 PM In reply to
    I would think it very likely that you would suffer from a good degree of background hum if you did this. Powerlink cables are well shielded to avoid this.
  • 05-15-2007 2:42 PM In reply to
    Agreed Peter. Not what I would do or recommend but in theory it is possible. Result would probably be less than acceptable!
    Regards Graham
  • 05-15-2007 9:15 PM In reply to
    • sunit
    • Not Ranked
    • Posts 2
    Thanks guys I will have to just pull the Beolink cables I guess
