Latest post 11-08-2008 12:44 PM by Medogsfat. 7 replies.
Page 1 of 1 (8 items)
  • 10-16-2008 1:14 PM
    Beocom 1600 / 2400 / 2500 - How to...?
    Does anyone know what sequence of keys I need to press in order to store some phone numbers in one or more of the memory locations (Beocom 1600 this is)
    i.e. key in phone number then...?  ENTER > MEMORY (No:) or   ENTER (then key in number, then...)  ENTER
     Think I've tried about 8 possibile combinations of buttons with no luck...  And it's supposed to be simple to use?
    Jack
    BV10(40) BV8-32, BV3-32, MX7000, DVD1, HDR1, V8000
    Beomedia-1, BS9000, BC7002, BC2300, BS5500, BM6500, BGCD6500, BM1900-2
    BL5, BL8000, BL6000, BL Penta3, BL3500
    Beovox MC120.2, 3000 Panels, CX50s, C75s, AND LOTS WIRES, BOOkS, MAGS n BITS (ebay sales: beo-store-uk)
  • 10-16-2008 1:20 PM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: Beocom 1600 / 2400 / 2500 - How to...?
    Hi
    I have the 2500 and I type the number, then Enter and screen says Enter the name. I type the name and Enter again. That's all.
    Quim
  • 10-16-2008 1:27 PM In reply to
    I am assuming you do not have a user manual which is available on the Beoworld site for silver and gold members.
    To add a number press ENTER then enter the phone number then press and HOLD the ENTER key down while entering M1 or M2 or 0 to 9 depending which memory location you are saving too, then release ENTER.
    Regards Keith....
  • 10-16-2008 2:18 PM In reply to
    Ta, very kind of you...
    Jack
  • 11-07-2008 7:00 PM In reply to
    Hi.
    An elderly friend had a Beocom 1600 for a very long time, and when it "grew old" she bought a second-hand Becom 2400. Of course there are no User Instructions, and the original ones disappeared long ago.
    Your information on adding numbers to memories will be very useful.
    How can we increase the ringer volume for incoming calls?
    Filed under:
  • 11-08-2008 9:08 AM In reply to
    To set the ringer volume you need to:-
    The left and right < > are used to set the volume up and down. To set the volume at a level when a call is received then:-
    Press MENU then 8
    Press ENTER
    Press and hold > until "ON" is shown in the display then press ENTER
    Use the < > buttons for the desired volume level then press ENTER
    Regards Keith....
  • 11-08-2008 9:19 AM In reply to
    Thanks very much for your prompt and helpful reply.  I am going round there this evening and will set the numbers and volume.
     Again, Many Thanks
    Filed under:
  • 11-08-2008 12:44 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    As a silver member you have access to the user guide which is on site for download.
    Chris.
