Latest post 10-15-2008 1:21 PM by Ben. 2 replies.
Page 1 of 1 (3 items)
  • 10-15-2008 9:47 AM
    Which (if any) Penta Speakers will work with Beosystem 3000
    Hi everybody.
     I have a Beosystem 3000 and was wanting to purchase a set of penta speakers. Can anybody tell me which of the Pentas (I II or III) will work best with the system?
    Dave
  • 10-15-2008 10:59 AM In reply to
    • magnushj
    • Top 500 Contributor
    • Joined on 08-16-2007
    • Trondheim, Norway
    • Posts 139
    • Silver Member
    Re: Which (if any) Penta Speakers will work with Beosystem 3000
    I have penta II's, and they are equipped with speakerlink connector. Should work with your beosystem. Don't hold me to it though. ;)
    Beocenter 9500+Beolab Penta mk2+Avant+MX7000+Beosound Ouverture+1xBeolab 6000 :)
  • 10-15-2008 1:21 PM In reply to
    • Ben
    • Joined on 12-28-2007
    • Taunton, UK
    • Posts 131
    • Silver Member
    Yep, you want them with the speakerlink connections, which I believe all versions to have. The Penta I's also have 'bare wire' type inputs too, which may or may not be advantageous for you.
    The displays won't work though, no matter which versions you choose.
    Avoid the Beovox versions.... The Beomaster 3000 amplifier is pretty anaemic at the best of times.
    Cheers,
    Ben
