1st March February 2012
Latest post 11-18-2008 9:39 AM by burantek. 20 replies.
10-15-2008 9:41 AM
apearce
- Joined on 10-26-2007
- Posts 80
Hi All, I'm pretty sure we've all had a bad run in with a spaghetti jungle at the back out our set-ups. What does everyone use to keep this under control?? I was thinking of velcro ties however i'd probably need a shed load. I've also seen in some dealers a type of mesh that the cables are fed through giving the look of one single run, quite tidy but i'd imagine this could be rather un-enjoyable to do... Thoughts? Ash.
Beosystem 3, Beosound 4, Beolab 9, Beolab 3, Beolab 8000
Quim43
- Joined on 11-15-2007
- Tarragona (Catalonia)
- Posts 1,030
Steve at Sounds Heavenly
- Joined on 05-18-2007
- In the cable workshop, Melton Mowbray, UK
- Posts 356
Hi, There are various "spiral wrap" cable tidy products available, as sold for tidying computer cables in offices. These are fairly cheap (ie. a few pounds for 5m in the UK). Although it is not usually possible within equipment stands, it pays to try to separate audio and mains cables away from each other to prevent interference (in the form of humming on the audio channels or clicks when equipment is powered up). This is not normally too much of a problem unless you have long cable runs, but it is worth considering to ensure that you get the best performance from your system. Best regards, Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
- Posts 356
Interesting thought Peter..... Let me know if you want some help turning your good ideas into a finished product!  Best regards, Steve.
Dave
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
I'm just amazed at how many cable there are coming out of that BV7!
Dave
- Posts 2,328
Quim43: Dave:I'm just amazed at how many cable there are coming out of that BV7!
Power, RF In, RF Out, 4 Speakers and Subwoofer, V8000, BS9000, Beomedia 1, TVix 6500, Satellite receiver and a IR cable for PUC. And I am happy I could take out two scarts and one optical cable for audio
can you daisy chain the speakers at least? Yikes well i don't have that much connected (THREE THINGS! AC, DVD, SAT) and it's still a horrific rats nest behind the TV cabinet ... hehe Peter your avant is impressive, but surely you don't have those 14 or so things connected
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
my avant pic has: (1) cable box running (4) lines / (1) masterlink to a bs9000 / (2) powerlink leads to bl4000 (front L+R) / (1) powerlink to bl6000 (rear L daisy-chained to R) / (2) power leads for surge / (1) avant power lead. i will be adding a non b&o sub prob this weekend which will add (1) rca line to the above mix. everything runs through the rectangular enclosure(s) at the baseboard/carpet interface. it took a lot of effort (and an 11 month old) to get the back of the avant that clean -but i enjoyed every minute of it, really!
Page 1 of 1 (21 items)
