1st March February 2012
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Re: Uppgrade a Beosound 9000 with new SW
Take a look at the FAQ. Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
B&Ola
- Joined on 04-16-2007
- Posts 302
Yes, I did before but that doesn't give the answers I need.
I want to know if this is a I can manage to do by my self.
What do you think? Is it?
/Ola
beoaus
- Melbourne, Australia
- Posts 445
A couple of obstacles; being the parts and the difficulty aspects. Here you can't get the parts without the installation. If you could....Going from a MK1 can require substantial changes which are different depending on your model number, so no!. Going from MKII to N.Music requires a chip upgrade however some early MKII's also require additional changes. If its just the chip I think others have been able to complete the upgrade. beoaus.
Hi I had my BS9000 MK1 upgraded to n.music and it was just the chip change. you only get n.music and n.radio no pin safe jon
Keith Saunders
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
To update the Beosound 9000 for N.Music & N.Radio it requires a chip change to version 2.2 or greater as shown below for the Mark I & Mark II. PROVIDED you understand and use static protection so as not to destroy any components including the new chip which means an earthed wrist strap and an earthed work area and you have a chip extraction tool, then it is a straight forward procedure.
B&Ola
- Posts 302
Thanks!
Is hard to open the outer chassie?
Can I use the MKIII service manual for this procedure?
/Ola
joeyboygolf
- Ely, Cambridgeshire, UK
- Posts 3,252
There is such a load of **** talked about this upgrade. I have done loads of them and all versions simply required a chip change. Where all these other stories come from is a mystery to me! Yes you can use the Mk3 service manual for help in getting it apart. Basically you will need to :- Remove the glass door Disengage the carriage Remove the rear(grey) covers Move a couple of ribbon cables Pull the top from the processor can Remove the chip as shown in the instructions that came with the replacement and replace with the new one Re-assembly is a reverse of the above I have never used a chip extraction tool. If you are sensible, you can lever them out with a small screwdriver! Unless you wear frilly nylon knickers you can earth yourself periodicaly by touching the chassis of the device. If you do wear frilly nylon knickers then you are possibly on the wrong website!! (joke!)
beoaus
- Posts 445
I'm glad someone has cleared this up. I have an old and unbelieveable $xxx quote for the upgrade which was justified by what I posted. It stopped me from moving to N.MUSIC. Worth re-investigating now. Thanks...
Seanie_230
- Joined on 04-20-2007
- Milton Keynes, England
- Posts 962
joeyboygolf: Unless you wear frilly nylon knickers you can earth yourself periodicaly by touching the chassis of the device.
im affriad i work with anti-static and the correct way woudl be to touch the chassis if indded it were plugged in and the earth connection to the mains outlet was connected otherwise they static has no where to discharge to
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
augs
- Joined on 09-17-2007
- Posts 73
So the part number of the chip is 8344087. Does anyone know the price of it?
Es hört doch jeder nur, was er versteht. (Johann Wolfgang von Goethe)
augs
- Posts 73
Great! Thanks a lot for this "cheap"  information
joeyboygolf
- Posts 3,252
Re: Upgrade a Beosound 9000 with new SW
seanklemis: joeyboygolf: Unless you wear frilly nylon knickers you can earth yourself periodicaly by touching the chassis of the device.
Actually that won't help either as a two core cable is used so the earth pin is not connected. In fact the earth pin may even be plastic!!! I am sure that in theory you are correct Sean but if we all stuck to theory then nothing would ever get done unless you pay £60 an hour for a fully kitted out electronics workshop to do the job! The premise that I work on is that I'm doing the job on the cheap so I'll take the chance that if everything is at the same potential (but possibly not zero) then there should be no problem. This premise has worked for me during many hundreds of jobs and I'll take my chances and save the money. I suppose that I should buy a wrist strap and I will probably curse when I zap my first component but hey ho!
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
joeyboygolf: The premise that I work on is that I'm doing the job on the cheap so I'll take the chance that if everything is at the same potential (but possibly not zero) then there should be no problem.
Not sure that we should be advising people to 'have a go' or 'take a chance'... You may indeed have done it hundreds of times, but imagine the disappointment if BeoWorld encourages a member to do a DIY job and then cause hundreds of pounds worth of damage to their unit. Removing a chip with a screwdriver can break the socket if you're not very careful - and as mentioned, static failures in todays electronics are quite high.. My own engineer (B&O trained with 20 yrs experience solely in B&O) has reported DIY jobs working at first then failing at a later date due to damage caused through cack-handed DIY work or poor earthing during repairs. Yes, you can do things yourself - but i would be cautious in recommending this, especially being a moderator and well respected. All cases like this should carry more caveats than a Russian Roulette tournament. Lee
Peter
- Joined on 02-12-2007
- Posts 9,572
I agree. I am sure Graham has managed just as he states but I would always advise the correct tool for the job and if you are not sure, get someone who is. I think 'having a go' with something worthless is always an option, but not with a valuable piece of B&O.
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
Taking proper antistatic precautions isn't expensive (see HERE for suitable earthing points, wrist straps and cords etc.). If you do this sort of thing regularly then it is a very worthwhile investment. The trouble is that you can do without and seemingly get away with it - however the damage may have been done and the failure will happen at some time in the future. Theres a decent pdf that explains all from Texas Instruments here but is slightly to large to attach to this post.
joeyboygolf
- Posts 3,252
9 LEE: joeyboygolf: The premise that I work on is that I'm doing the job on the cheap so I'll take the chance that if everything is at the same potential (but possibly not zero) then there should be no problem.
This is an enthusiasts site not a commercial operation as we are contionually being reminded. If we were all working for B&O (maybe we are!!!) then I would be more considered. I was simply attempting to help a fellow enthusiast. If that was wrong then I hold my hands up high. "I done it guv" and I'm prepared to fall on my sword. Please remove my moderator/technical advisor status. I will retire to the "back benches" where I can hopefully still contribute. Watch out Peter, you might want to sharpen your moderators pencil again just like the old days!!
koning
- Netherlands
- Posts 2,670
What joeyboygolf said was nothing wrong with it. Even a child knows the risk when you play with electricity!!!!
stotty1111
- Joined on 12-16-2007
- UK / France - Nth Worcestershire/Finistere
- Posts 924
swalut all think i'm with graham here(joey etc) - i have built and used many differing modules for r/c equipmeny boat etc - have never had static damage probs - however i may one of the lucky ones without a high static body charge - my good woman has terrible probs of static with our car - doesn't affect me - maybe a case of no sense no feeling! tony s
I always try to operate using/following the KISS principle -- Keep it simple stupid!
Keith Saunders
- Posts 3,810
The issue of what is involved in updating the Beosound 9000 software to support N.MUSIC and N.RADIO has come up several times on this forum and for this reason I have created a Beoworld information page on the subject which can be viewed HERE There is detailed instructions along with pictures to help members who feel able to perform this upgrade. Please ensure you use all neccessary anti-static protection when performing any work on any electronic equipment.
Page 1 of 1 (23 items)
