1st March February 2012
Latest post 12-28-2008 4:10 PM by Jandyt. 5 replies.
10-14-2008 10:11 AM
Chieljan
- Joined on 09-21-2008
- Posts 24
Beomaster 1600/1700 wall mountable?
Hey all, quick question, is a beomaster 1600/1700 (you know, the one with the rubber tracks for tuning and volume) wall mountable? Can't seem to find it anywhere... Thanks! Chieljan
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
Re: Beomaster 1600/1700 wall mountable?
chieljan, i happen to have one sitting right next to me! i don't believe that b&o ever offered an official kit for this purpose on the bm1600/1700... but, good news! there are (2) thru holes on the base plate that are wide open and would provide an easy way to arrange a wall mount. i would suggest using hi-cap in wall anchors, then opening the lid on the prop rod and running some fasteners w/ large od washers from the inside out. alternatively you could lag at least one side into a stud using the same method. should work fine! btw, you got me really excited about this, so i took a look at the matching bc1600 also -unfortunately -it's base is plastic and packed solid w/ no matching thru holes, so sadly i couldn't mount them together (at least in the same fashion).
Chieljan
- Posts 24
Hey guys. Thanks for the replies!
Friend of mine maybe wants to buy a 1600, he'd like to wall mount it and use it as an amp for his beocenter 2500... I'll let you know how it works out, we're definitely going to try! (after looking into that adhesive, of course ) Chieljan
richtoy
- Joined on 09-20-2007
- Valkenburg, Netherlands
- Posts 184
Andy, Having just stripped and cleaned one of these beauties I found that the glass panel is not held on by adhesive tape but is instead held in a slight groove between the top and the bottom aluminium panels. The top amd bottom edges of the glass itself are slightly machined to allow a good grip. The glass can be removed by removing both catapillar tracks which themselves hold the top and bottom aluminium panels together. If the glass is loose it is possible someone has not correctly replaced the catapillar tracks after cleaning. Regards Richard
Some of my B&O: BV3/32, MX7000, MX5500, LX5500, MX4000, BM8000, BM6000, Overture, BL8000, BM6000 Quad, BM4400, BM3400, BG-CDX, BM3000, BM1001, BM1200, BM1600, BM1700, BM1500, BM1400, BM2400, BM2300, BM4500, BM4000, BVM70, BVS45-2, BVS60, BC7700, BM2200, BM1900, BG8002, BM1202, BVPenta, BVP45
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Thank you Richard. I have two of these units, one with the glass in situ and one without. Perhaps in 2009 I'll get round to tidying them up and maybe mounting one on the wall in one of the guest bedrooms. Andy T.
Page 1 of 1 (6 items)
