Latest post 10-13-2008 2:19 PM by KingOfSnake. 2 replies.
Page 1 of 1 (3 items)
  • 10-13-2008 7:45 AM
    • opesvw
    • Not Ranked
    • Joined on 10-13-2008
    • Posts 1
    • Silver Member
    MX8000 (2004) with Sky+ ?
    Hi, I'm new to this -- can anyone tell me whether I can easily use an MX8000 (2004) with Sky+ ? It has a Set Top Box Controller module. Many thanks
    Filed under: , , , ,
  • 10-13-2008 9:56 AM In reply to
    Re: MX8000 (2004) with Sky+ ?
    You may have to have it serviced, to add the Sky+ settings in the STB List, but I'll check tonight to see which setting I am using. It might be the same as for the standard Sky box.
  • 10-13-2008 2:19 PM In reply to
    PACE SKY+ and SKY DIGITAL are two separate settings for STB-C I think.  I would be surprised if a 2004 MX8000 did not have PACE SKY+, depends when it was manufactured.  What serial number is it?
