Latest post 10-14-2008 3:32 PM by david707. 7 replies.
Page 1 of 1 (8 items)
  • 10-13-2008 6:39 AM
    MX4000 service menu access
    I have an MX4000 sw3.1 s/n 13718842
    Is it possible to access the service menu via beo4 or are there some pins to short as on the LX5500?
  • 10-13-2008 9:42 AM In reply to
    Re: MX4000 service menu access
    Have you tried Menu, Zero, Zero, Go ?
  • 10-13-2008 1:13 PM In reply to
    Menu 00 GO just displays the software version.
  • 10-13-2008 1:25 PM In reply to
    Same with my MX6000 with sw 3.1, I believe it has the same chassis. You need to short the service mode pins inside to get the full menu.
    -mika
  • 10-13-2008 1:29 PM In reply to
    Thanks for that Tournedos. I was hoping for a remote controlled solution!
    David
  • 10-13-2008 1:36 PM In reply to
    What extra settings do you get for that TV?
  • 10-14-2008 2:49 PM In reply to
    When I press Menu 1 1 Go, I get a variety of settings on my MX 7000. What are they used for?
  • 10-14-2008 3:32 PM In reply to
    That's the service menu - works on the 4000 too so I need not have taken the back off! Mine simply needed a very slight tweak on the geometry like you might perform on a computer monitor. There are lots of picture settings and others for colour etc. My advice is to always make a note of the original settings.
    Regards
    David
