Hello
Is possible to connect directly the Beo 7700 to a Beolab 8000? I was checking the electrical scheme of thr Beo and there is the dummy Line connector that could be used as a Beolab feed BUT there is no way to control the volume/bass/treble sections...
In the beo ampli section there are two TDA1074A that controls volume and tones, so could be used the last output (just before the ampli section input) to pickup the signal and send to the beolab (maybe using a 1K resistor) or not?n
Thanks a lot and sorry for my english.... :)
