Latest post 11-01-2008 5:44 PM by thorne. 5 replies.
Page 1 of 1 (6 items)
  • 10-11-2008 12:22 PM
    cleaning cloths for LCD TV screens
    Can anybody recommend what I should be using.  I thought microfibre was the answer to my prayers, then I read in the BV7 manual that these cloths could damage the coating
     Having said that, my dealer mentioned 3M microfibre cloths and said that B&O recommend them
  • 10-11-2008 12:50 PM In reply to
    • Weebyx
    • Top 200 Contributor
    • Joined on 06-30-2008
    • Denmark
    • Posts 321
    Re: cleaning cloths for LCD TV screens
    thorne:
    When i bought my BV4 there was excactly a 3M cloth included in the package, so i will recomend buying such a one from your dealer.
    /Weebyx
  • 11-01-2008 10:27 AM In reply to
    Thanks.  I ordered one which has now arrived.  Do you use it wet or dry?
  • 11-01-2008 10:29 AM In reply to
    • Weebyx
    • Denmark
    • Posts 321
    thorne:
    I use it dry.
    /Weebyx
  • 11-01-2008 10:37 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Why would a 3M Microfibre be better than another decent branded Microfibre cloth? Huh?
    We use Tesco own brand microfibre cloths with foam glass spray, and we have never once had an issue with coatings.  I would guess i have cleaned at least a thousand TV's this way.
    Lee
    PS - Make sure you wash the cloth regularly though - on its own.  A greasy microfiber is a real pain as it will never do the job.
  • 11-01-2008 5:44 PM In reply to
    Thanks all.  The reason I ordered a 3M cloth was because this was the brand recommended by my dealer, and as I said previously, it does specifically state in the BV7 manual to beware of some microfibre cloths.
     I wish I had received your reply earlier,Lee, because the cloth cost an arm and a leg!
