Latest post 05-15-2007 9:05 PM by 9 LEE. 3 replies.
Page 1 of 1 (4 items)
  • 05-15-2007 6:39 AM
    • Kevin
    • Top 50 Contributor
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    The Workbench Section is open!
    Well it's open but a bit empty!
    So don't wait outside the door to see what everyone else brings in.
    Bring your current projects, favourite fixes and of course your opinionsCool
    Some of you had older projects on the old site so it would great to see them brought here; ice amps into passive speakers, various cases turned into media centres and upgrading the chips on your B&O.
    Happy to champion the new section but if it doesn't get used then we don't get to keep it[:'(]
    cheers,
    Kevin
  • 05-15-2007 6:44 AM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Re: The Workbench Section is open!
    The ability to edit your own posts seems to be disabled in the Workbench Forum. Can we have it back pleaseBig Smile
  • 05-15-2007 8:52 PM In reply to
    Hello Kevin,
     Are the powerlink cables essentially a 8 pin din. I'm wanting to build wall sockets..and put the wire cleanly in the walls.
    Would this work for the wall socket. http://www.durhamradio.com/s/product.php?productid=43825&cat=1763&page=2
    thanks
  • 05-15-2007 9:05 PM In reply to
    • 9 LEE
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Puncher:
    Your wish is my command! - try it now.
    Right, back in my bottle...
    Laughing
