Hi, I have beolab 8000 & beolab 6000 and want to attach them to non b&o preamp. Is there any special aspect I need to check in the preamplifier ? Is anyone else using a preamp successfully with these speakers? Would appreciate suggestions. Thanks
varunseth: Hi, I have beolab 8000 & beolab 6000 and want to attach them to non b&o preamp. Is there any special aspect I need to check in the preamplifier ? Is anyone else using a preamp successfully with these speakers? Would appreciate suggestions. Thanks
You need to supply the speakers with 5-12V to make them power up. it is the yellow wire of the powerlink cable.
/Weebyx
Weebyx: varunseth: Hi, I have beolab 8000 & beolab 6000 and want to attach them to non b&o preamp. Is there any special aspect I need to check in the preamplifier ? Is anyone else using a preamp successfully with these speakers? Would appreciate suggestions. Thanks You need to supply the speakers with 5-12V to make them power up. it is the yellow wire of the powerlink cable./Weebyx
Not true, I'm afraid.
The OP will be using the line socket then the speakers will wake up on receiving a signal and switch off a few minutes after the signal stops.
Regards Graham
joeyboygolf: Weebyx: varunseth: Hi, I have beolab 8000 & beolab 6000 and want to attach them to non b&o preamp. Is there any special aspect I need to check in the preamplifier ? Is anyone else using a preamp successfully with these speakers? Would appreciate suggestions. Thanks You need to supply the speakers with 5-12V to make them power up. it is the yellow wire of the powerlink cable./WeebyxNot true, I'm afraid.The OP will be using the line socket then the speakers will wake up on receiving a signal and switch off a few minutes after the signal stops.
aaah, :) That is what the line socket is for :)
