1st March February 2012
Latest post 10-13-2008 1:24 PM by tournedos. 16 replies.
10-10-2008 1:44 PM
LordGreystoke
- Joined on 10-10-2008
- Posts 8
How to change picture to 16:9 on a MX 4000?
Hi there! After changing to a new cable company, I need to adjust my telly to 16:9 picture, as the picture as it appears now is squeezed from the sides, and everybody is looking like Goofy... But I can't figure out how to change the picture. I have installed the format button, but it doesn't work. Is it possible to adjust the picture to 16:9? The telly is from 2002, so it shouldn't be a problem. Does anybody know what to do? LordG
KingOfSnake
- Joined on 02-07-2008
- Posts 359
Re: How to change picture to 16:9 on a MX 4000?
Hi, I read somewhere that you press LIST until you see FORMAT and then press 3 - you can choose between 14:9 (1), 15:9 (2) or 16:9 (3) - I think you'll get black banners above and below on an MX4000.
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
You cannot change the setting on any 4:3 TV, but you can surely change the setting to 4:3 from 16:9 in your set top box setup menu. p.
KingOfSnake
- Posts 359
I was sure you could - sorry - think I have done so on a Beovision 1 but maybe I am mistaken.
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
BV1 is newer technology so it might be able to do that - your MX4000 I believe is internally pretty much the same as my MX6000, and it can only do 4:3. It's a little odd, since just about every other manufacturer has had 16:9 support as a standard feature since the mid-90s... Shame really, since the digital scaling done by an STB/DVD usually results in a noticeably worse picture than if the TV set dropped its scan height to 16:9.
PhilLondon
- London
- Posts 2,545
I have checked on the manuals, BV1 has indeed the Format feature, the MX4000 does not. Just dig into the cable set to box settings and turn it to 4:3 and all will be fine. p.
The Plumber
- Plymouth UK
- Posts 669
even if you change the set top box to 16.9, it will not come out on your mx4000 in that format. to be short and sweet you will never get 16.9 on your mx4000, mx4002. but you can do it on an mx4200. i only know this as ive asked the same question on here and tried all the options and it dont work. like the previous poster says, if you set your set top box to 4.3 your picture wont be squashed, but this is a pain if your mx is in a link room as you will need to change it back when in the main room see here http://forum.beoworld.org/forums/thread/103503.aspx
Never Mind The Ball-Cocks
www.markmossplumbing.co.uk
A labourer uses his hands A tradesman uses his hands and his head A craftsman uses his hands, his head and his heart
LordGreystoke
- Posts 8
Thank you guys for all the answers! As my set top box does not have any possibilities for switching between 4:3 and 16:9, it looks like I have to buy myself a new telly! But I'm really very found of the MX-series! Is the 4200-model, the only one that can adjust the picture to 16:9? Can't find the same information about the MX8000. Does anybody know? Regards LG
PhilLondon
- London
- Posts 2,545
You can download the manual of most TVs on this site if you become a member, or for some TVs on the B&O official web site. You can then search the manual for the FORMAT feature. p.
tournedos
- Finland
- Posts 5,808
LordGreystoke: Thank you guys for all the answers! As my set top box does not have any possibilities for switching between 4:3 and 16:9, it looks like I have to buy myself a new telly! But I'm really very found of the MX-series!
I'd rather get a new STB Seriously, I have never seen a box without a 4:3/16:9 setting. What is it?
LordGreystoke
- Posts 8
It's a Fujitsu Siemens model mpc d2644. My English is not that good, but it's a box that connects the telly to the fiber cable. It's possible to play dvd's on the box as well. The same as a STB?
LordGreystoke
- Posts 8
tournedos: LordGreystoke: Thank you guys for all the answers! As my set top box does not have any possibilities for switching between 4:3 and 16:9, it looks like I have to buy myself a new telly! But I'm really very found of the MX-series!
This is the box: http://www.fujitsu-siemens.co.uk/rl/servicesupport/techsupport/ProfessionalPC/ESPRIMO/Q/EsprimoQ5020.htm LG
Graham1982
- Joined on 11-22-2007
- Cambridge, England
- Posts 531
Hi: Someone should come along to correct me if I am wrong. A lot of the following advice is based on assumption having had a brief look at your "set top box": I have concluded that this is not a simple set top box at all but more of a mini media server. I think that this is running windows XP and as such is more PC than television receiver. It may well have a freeview decoder installed yet this is secondary to its main function which is to stream media to all things on your wireless network. I imagine that when you watch televison on this you have to do it through a piece of software. If this software does not allow you to do 16:9 then you will have to install another piece of software that does. However there may be compatibility issues with the decoder unit built into the machine. This could all be a gross misunderstanding but I think I am right. If you just want to watch freeview in 16:9 just get a cheap box that does only this for about £15 and it will solve your problem a lot easier than messing around with software, whch I think is what you are going to have to do in this situation. Thanks Graham
LordGreystoke
- Posts 8
Thank you Graham! I think you're right! But what kind of box could change the picture to 16:9? Do you have a link to a web site? Kind regards LG
Graham1982
- Posts 531
Hi: Where do you live (UK?)? If so any Freeview box will do the trick and you can pick these up from any electronic store. I am unsure as to the roll-out of freeview in Europe - I have only spent long periods in Spain and France and in the places I stayed, they used cable or sky.
LordGreystoke
- Posts 8
I live in Norway, and I don't think there are any Freeview boxes around here. So, the only solution for me - it looks - is to buy myself a MX4200. If I can find one ;-)
tournedos
- Finland
- Posts 5,808
"Freeview" is a strictly UK only term for what the rest of the Europe calls terrestrial digital broadcasting, or DVB-T. Dunno if that helps, but in any case it's not a box that will convert the signal from the whatever player thing you have there now - it's a separate device for watching off-the-air broadcasts. Maybe http://www.nrk.no/informasjon/ is more helpful But seriously, you should look into how you can configure your current picture source to do the 16:9 -> 4:3 conversion (letterboxing), if you want to keep watching it. I can't believe it wouldn't be possible.
Page 1 of 1 (17 items)
