Latest post 10-14-2008 2:53 PM by stotty1111. 6 replies.
Page 1 of 1 (7 items)
  • 10-10-2008 9:14 AM
    BeoCentre 9xxx Wall Mounting
    Hi, I'm thinking of relocating one of my BeoCentres and want to wall mount it and have a couple of questions about that.
    1. Did B&O ever do an official wall mount for these?
    2. I seem to rememebr somewhere in the dim and distant past that somwone 'made' their own one that was at 45 degrees- any infor?
    3. Any other suggestions? - and if it to go where I want it can't sit on anything as such......... :-(
    Or do I just have to get a shelf built?!?!?!?
     Cheers muchly
     GUY
    P.S. If anyone has any Beolab 1's or the active flat wall mounted ones that they may be looking at selling PM me as the ones I was looking at have been sold.... :-(((
    Train Hard - Run Fast - Hit to Kill!!!
  • 10-10-2008 9:37 AM In reply to
    Re: BeoCentre 9xxx Wall Mounting
    B&O always said that these Beocenters should be flat on a shelf or similar. Wall mounting is not possible as the cd mech is not fixed in place inside the unit.
    Medogsfat did wall mount one a few years back at approx 35 degrees with success. Worth sending him a PM
    Regards Graham
  • 10-10-2008 2:24 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    hi there
    ihave a bc9300 located about 3"(75mm)above the floor on a shelf - the unit is supported on 2 x wedge shaped pieces about 1"(25mm) thick - the rear height is 3.25"(80mm) and the front is about 0.25"(6mm) -this arrangement imho shows the unit off to advantage - think the angle is about 25 degrees!
    the wedges are held in place by double sided tape and located just inboard of the front rubber feet in a front to rear arrangement - the wedges also have small neoprene feet on the underside to prevent sliding around - can't load pics hte batts in the camera need charging however if you want pics let me know and i'll give you a link to photobucket
    salut
    tony s
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 10-10-2008 3:55 PM In reply to
    • kallasr
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Pictures are very welcome!
    Thanks in advance.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 10-11-2008 8:55 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
  • 10-14-2008 12:22 PM In reply to
    Nicely customized BC setup. Although i wouldn't dare to put my BC's glass-side against any surface. :) I've read so many stories here about the glass panel falling off of equipment it almost scares me to have the BC on hand of my roommates since they really don't see the difference between pressing and touching. >.< The other thing they don't understand is my interest and affection for B&O equipment but that i more or less understand. ;)
  • 10-14-2008 2:53 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    no worries about glass falling out the foam recently split and both panels were re attached with double sided tape the unit was placed on  a very soft persian type rug swo no probs from scratches etc there
    tony s
