Latest post 03-24-2009 3:11 AM by Dillen. 6 replies.
Page 1 of 1 (7 items)
  • 10-05-2008 2:25 PM
    Beovox S45 loose bass magnet
    Hello,
     I have a Beovox S45 speaker where the bass driver magnet has broken off. I there any way to glue it back on? Or is driver replacement the only option?
     VR
  • 10-06-2008 3:19 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beovox S45 loose bass magnet
    Sadly a quite common fault on these wonderful speakers, especially when transported.
    You can glue it back on but it's practically impossible to do so without damaging the coil since it gets squeezed between the magnet and the cylindrical center piece. Aligning the magnet while the glue sets is also difficult due to the magnetic forces.
    I've added glue around the magnet to fix it to the chassis on the ones I've had in for repairs/recap'ing, simply as a precaution.
    I would look for a replacement woofer. Get a good used original driver, no modern woofers will match the original specs.
  • 10-06-2008 4:33 AM In reply to
    Yes, it seems to be impossible to glue the magnet from the back. Since the woofer is practically scrap I think I will try to remove the cone/spider/coil assembly and see if it could be done using some kind of spacers inserted from the front to align the core correctly. As this will propably fail I need to place a wanted ad for the woofer or single speaker.
     I was considering replacement with these http://www.visaton.com/en/chassis_zubehoer/tiefton/w200s_4.html . Any idea if they would be suitable if all else fails?
     VR
    PS. It was transport damage. And it seems that glue was quite sparingly used originally.
  • 03-23-2009 12:52 PM In reply to
    • Folke
    • Not Ranked
    • Joined on 10-24-2008
    • Stockholm, Sverige/Sweden
    • Posts 30
    A string of good 2-component epoxy glue along the joint right here, then? As a precaution? Or am I wrong? Unsure
    /Folke
    BG 6000 Quad (two!), BM 3000, BM 5000 (2005), BV S45, BV M70 with trumpet stands
  • 03-23-2009 6:03 PM In reply to
    • Dillen
    • Posts 5,008
    Glue around the ridge where the magnet (darker part) meets the base of the
    metal basket.
    That'll be just above the yellow line in your photo.
    I like to sit the woofer on its magnet (cone upwards) and then place the glue on the edge of the magnet
    that sticks out nicely.
  • 03-23-2009 6:22 PM In reply to
    • Folke
    • Not Ranked
    • Posts 30
    Aha! That part can come loose! So it's more like this?
    Thanks, Martin! Smile
  • 03-24-2009 3:11 AM In reply to
    • Dillen
    • Posts 5,008
    Exactly !
