Latest post 10-05-2008 1:17 PM by LarsJensen. 3 replies.
Page 1 of 1 (4 items)
  • 10-05-2008 3:24 AM
    • beoben
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Germany
    • Posts 189
    Contributor status
    is it possible to see when you become for example a top 150 contributor? At the moment i´ve about 120 posts and i´m a "200" contributor!
    Are there any statsitic?
    I want a BV 10
  • 10-05-2008 5:36 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Contributor status
    Just hover your mouse over the green bars under your avatar! I can see you are a top 150 contributor.
    As for statistics, go to "View all users", in th search box type a    %
    then in the box below, select "Sort by # of posts" Leave the rest blank, and click 'Search'
    Andy T.
    Poor me, never win owt!
  • 10-05-2008 12:23 PM In reply to
    • beoben
    • Germany
    • Posts 189
    Thank you Andy.
    Sorry but i knew this already.
    I want to know how many more posts i need to get the "next" level???
    I want a BV 10
  • 10-05-2008 1:17 PM In reply to
    • LarsJensen
    • Not Ranked
    • Joined on 04-25-2007
    • Copenhagen, Denmark
    • Posts 65
    When you perform the search mentioned above and sort the result by "# of post" then you cuold go through the list to find your exact rank and spot how many more post the users ranked higher than you haveSmile
    /Lars - working his way upWink
