There isn't an unlock code, but Italy is region 2 - not knowing which country you live in makes it difficult to know which DVD region you are in, but if you are in Europe you are region 2 and all will be fine - if USA, region 1, but the TV won't work in Italy anyway as the transmission is different (USA = SECAM - EUROPE = PAL)
